CDI torque wrenches on ebay
bmwpower
Good deal. The only problem I see is that most of the stuff found at that torque are 1/4" drive, small fasteners.
P
plinker
Northern Wi
Well the torque wrench came a couple of days ago.
The auction said lightly used...The darn thing is brand new! No wear on the square drive to indicate a socket was ever put on. It is a quick release, FWIW.
It also has the normal on/off and it has a third setting for non-ratcheting use.
The calibration certificate showed that this one is accurate in clockwise to 1.2% (+/- 4% is the tolerance)
For small engines, ATV's ete.. these work great, Alot of times you have better access or ease of use with a smaller torque wrench.
besides the adapter is our friend:lol_hitti
Merkava_4
Clovis, CA.
That's a hellava deal for someone who needs a torque wrench for their upper and lower intake manifold gaskets on a GM 3800 V6.
Defender Chassis
Williamstown, WV
I bought one also and I think mine looks new also. At most it was used a couple times. The same seller also puts a couple up for auction on a regular basis. I got mine that way for $46 instead of the $50 buy it now add. Looks like they might be all sold out and may start going cheaper in the near future. I wish now I had waited.
jay50
If I am needing to torque in the low inch/lbs range, I use a dial torque wrench, not a clicker. I just don't trust these clickers on low torque applications such as intake manifolds on 3.1/3.4s. It's just my preference...:thumbup:
Treeman
Plinker/Defender,
How does the ratchet mechanism feel on these wrenches. Are they "fine" tooth?
Thank you.
P
plinker
Northern Wi
It's a 24 tooth mecanism similer to the older 1/2drv proto ratchet I have. I'm guessing it has about a 9* swing arc , about the same as my S-K 74076 torque wrench.
It has very little play in the ratchet head and is smooth.
I played with it a little yesterday and it's pretty nice.
Treeman
Thank you. Not too long ago I called CDI and asked what the differences were between a CDI wrench and a Snap On (micrometer clickers).
The phone tech. said the important part, the internal mechanisms, are identical. Snap On uses their sealed ratchet head and CDI uses a "very good" imported ratchet head.
