Ceiling color?
cartunes
Near Richmond, VA
Question for those with gray wall color- is your ceiling white or gray?
I plan to paint the lower 4' of my walls medium gray, and the upper part silver gray. Not sure if the ceiling would be ok in gray.
Any thoughts?
Thanks, Ron
MikeinLA
It would probably look good with the gray walls. I think the only consideration is the light reflectivity of the gray versus white. If that's not an issue, the gray would be fine. Sure makes the painting go easier when the walls and ceiling are the same color.
Mike
jshillin
PA
I have light grey walls and a white ceiling. You want your ceiling as bright as you can get it.
C
cartunes
Near Richmond, VA
Mike,
A buddy of mine was wearing the same shirt as your Avatar, and went in to a Waffle House here in Virginia and they refused to serve him because of the shirt!! In a Waffle House, they should have bowed to him !
