dragginbalz
I have done some research on the metal (both steel and aluminum soffit) and they both look great! I was going to contact Menards for another quote and noticed that they now have a PVC interior liner as well called Pro-Tuf for $31.39 / pc for a 12'x36" pc.
The cost seems about the same as the steel to do my garage (around $400-$500 with J channel and screws), but I think the PVC might be a little easier to work with, cutting electrical boxes, etc.
Anyone use this stuff? Any opinions over using steel?
http://www.midwestmanufacturing.com/MidwestManufacturing/productDetail.do?groupId=7&productTypeId=46&lineId=178&productId=1383
Also, is it recommended to run the panels perpendicular to the joist like drywall? OR can you run it parallel?
Thanks in advance!
Thanks in advance!
