PelicanPines
Forgive me if this has been previously posted but... In my searching... didn't see it.
I have a Hunter ceiling fan where the lights stopped working. Bulbs were confirmed blown... new bulbs didn't work.
Troubleshooting began.
No electricity in sockets.
Yes to electricity at the top of the fan in the electrical box.
Yes to electricity at the internal connection of the fan to the lighting "kit".
No electricity at lighting switch pull chain on the unit.
Checked all internal wires within the lighting "kit". NOTHING looked wrong. Checked continuity between the top connector and the sockets... nothing. Checked the function of the pull chain switch... worked as expected.
When tracing the internal wires... there is a blue wire at that top connector that is spliced into a much smaller gauge wire that in turn is spliced into the black wire that feeds the pull chain switch.
Disconnected that smaller gauge wire and found a part number Y59 B 120C ... it is a wattage limiter. Put in place as part of a 2005 energy compliance effort to limit the wattage in ceiling fans to no more than 40 watts per bulb.
I had 40 watt bulbs if you were wondering.
Checked the continuity of this wattage limiter and it failed. It has no reset... it is a failed component. At most this thing is about $1... if it could be found, I figure.
Contacted fan manufacturer who didn't want to hear it... they pointed me to the fan capacitor and it's failure requires a complete ceiling fan replacement.
So... I come to understand... this Y59 B 120C component is not a safety feature but a resistor to prevent you putting bulbs that are too high wattage in the sockets.
It fails and renders the lights not working if you try a higher wattage bulb.
I also come to understand you can remove said "Wattage Limiter" and the light will work fine. There is some responsibility on you to use the correct wattage bulbs however.
In the end... I fixed it... I have light... I have a project ticked off my to do list.
