Ceiling Fan Shop?
karoc
Hemphill Tx
Ok before everybody start recommending Big *** Fans, well their like Festool in my world just out of my league.
With summer temps coming on strong, I came across ceiling fan with 100” blades at 300.00. Dang if it actually pushes air down from my 12’ ceiling height that would be great. I’m sure this is old subject, ceiling fans for shop, but wondering if there’s anyone that can say their fan actually works? Not just for shop declarations, but moves air. With me being able spend more time in shop trying finish my 1000sq ft retirement home, it be nice be cooler and maybe keep mosquitoes off of me. Any thoughts, suggestions, pics, links? Day dreaming-Tks
y'sguy
Tulsa, Oklahoma
Any easily movable fan on the floor works better for me. Cheaper. Not hanging from the ceiling. Especially if you have a 12' ceiling.Lots of hot air up there. If you can find an old attic fan, set on its side, with protection around it, Perfect. Roll it out of the way when you're done. I use an old furnace fan. It was almost free. Mounted on casters After I wash out the garage I use it to dry the floor. Takes just a minute. The ceiling fan in my art studio with high ceilings was a complete waste of time and money.
nadogail
Coronado, CA
We used Ceiling fans in the house until we had the Air Conditioning installed. My shop has several floor fans, all discarded by former tenants.
My former tenants have left behind many useful things.
Hank11
Tennessee
Yes, you want a fan and yes, it’ll move air and make the space more comfortable. And if you live in a place with high humidity, a dehumidifier will help in your shop a lot too.
LeonardY
Southern California
I use a Vornado garage fan came with some wall mounts.
I also have a Jet air filter. It’s a bit loud on full but low it’s fine to me.
I put a deflector on the output of the Jet to better circulate the air.
WildBill
PNW
I just have a inexpensive 58" one in my 24x36 shop and it makes a big difference. Especially when I finally remember to switch directions on it every spring/fall so it moves the hot air the right way.
bluedog225
Texas
My big 10 foot $300 Home Depot fake big *** fan doesn’t move a lot of air. I think it’s too close to the ceiling. Have to build a box to move it down.
Next time it’ll be a wall mounted fan
jmarkwolf
Southeast Michigan
I have a Hampton Bay 54-inch ceiling fan (no light, wired control) in my 28ft x 30ft x 10ft shop, purchased from one of the home supply big box stores (can't remember which). The fan runs 24/7 and has done so for 13 years now.
The blades are "aerodynamic", meaning efficiently twisted like a propeller, and at the lowest speed works great at uniformly circulating both heated and air-conditioned air year-round. Any higher speed would "sweep the floor" from 10 feet up.
I installed the fan in December 2013 when I realized the heated air in my new shop stratified badly, meaning the upper half of the room was comfortable, but below the belt was very cool. After installing the ceiling fan, the heat was uniformly distributed.
I'll buy the same fan again when this one needs replacement, if it's still available.
Notgrownup
Snow Hill NC
We just installed 6 10’ CANARM Fans in our warehouse at work, ceilings at 30’ high and we feel it. They were free from a Duke energy grant we just had to get them installed. Big As fans are very nice but holy shmoly, they are expensive.
Lassen Forge
We installed ceiling vent fans in the old garage in Sacramento, the heat build up up there was WAY too intense, pushing it down would have been disastrous... better to flush all that heat outside. Had vents near the baseboard to let air in, also we had some old variable controlled electronics rack fans (3x4 grid, about 4 of them) in the windows to draw more air in for the soffit blowers to remove...
I eventually built a swamp cooler gig in one of the (former) windows to get some moist, cool air in there... but the biggie was venting the heat OUT.
No way I would have put a big air stirring fan or 3 in the shop like we had in the bedroom etc... it would have done nothing but push superhot air down at us, or draw that heat along the walls to the floor to be recycled up. Air movement is fine, but not if it's a convection oven.
bdbecker
Iowa
HVLS (High-Volume Low-Speed) fans like Big *** fans (and any of their derivatives) work by creating a low speed, but larger column of air when compared to a conventional ceiling fan. If your shop is not conditioned, circulating air using a HVLS will not do much to actually cool the space, it'll just make the temperature more consistent throughout. Because they are designed to circulate air efficiently and break up stratification, they do not necessarily create the breeze effect that people are accustomed to from conventional, higher speed fans. It's not that HVLS fans don't work, they just work differently.
If you want to feel a breeze and keep the mosquitos off your back, you won't be happy with a HVLS fan. A good size barrel fan (or two) pointed at your work area would be the better option.
bluedog225
Texas
sounds right.
But the fans at Costco sure do blow
jmdirk
I installed two cheap industrial fans from Home Depot. Wired, no lights, just basic fans. I think they are in 50-52 inch range. You definitely feel the air moving when you've got them on medium or high. I think they were $200 CAD at the time.
bwringer
Indianapolis
The size of the shop matters... some of you are talking about really big shops with HVAC, some are talking about unheated/uncooled garages .
As mentioned above, in an un-air-conditioned space like yer average garage or small shop, I'd want to vent that heat out in the summer rather than stir it up and mix it with the cooler air below. So a gable or attic fan, depending, would make more sense here, along with some floor or wall-mounted fans for local cooling and to perhaps slightly inconvenience the mosquitos.
The OP mentioned 12' ceiling and mosquitos, so that would seem to imply a smaller shop or garage, often used with the door open.
Steve W.
Southwest oHIo
How high is the ceiling and how close is the fan to it?
I don't have any fans in the shop, but have several in the house. House ceiling is about 7' 9", so we have "ceiling hugger" fans. I have found that at any speed faster than LOW, the fans simply refuse to blow DOWN. Mainly due to supply starvation. With the fan blowing down, air needs to move across the ceiling to get above the fan blades. Due to the hugger situation, there is simply not enough room. The bigger the fan, the bigger the problem.
I have also found that with the fan blowing UP, air above the blades moves across the ceiling quite nicely, gets to the walls, drops down, then returns to the area under the fan for another cycle. Nice air movement in the room, but no direct breeze blowing on me. :thumbup: Yes, this works for heating or cooling seasons. As someone previously mentioned, it's more for removal of air stratification than it is for 'cooling' breezes.
Because of this behavior (and my preference for not having air blowing directly on me), I don't even bother to change fan direction with the seasons. They always blow UP.
dwk000
I have the Home Depot 10' fan. It moves plenty air, I have mine on an 6 foot extension. For the money its a good deal has the wall mounted control, would do it again.
Burl
Where Mountaineers are free
I have an Envirofan that has been in my un airconditioned garage for about 18 years now. 12' ceiling, 32 X 30. moves air around good. Runs a LOT in the summertime.
Stuart in MN
Minneapolis
Ceiling fans are best used in a conditioned space to reduce stratification, in my opinion. They are more important during the heating season to get the hot air that's up at the ceiling down to where you are. I would rather install several small inexpensive ones than one of those big ones, they are likely to interfere with your overhead lights so you'll get a strobe effect every time a fan blade passes in front of the light fixtures.
Shoester
Kansas City
I just installed two of the 120" HVLS fans from Parrot Uncle. Think I paid $368/fan with a 15% discount code they emailed me. 16' sidewalls with scissor trusses puts the ceiling height where the fans are mounted at about 20', and they are hanging down on a 4' down-rod.
So far I am very pleased, they move a large amount of air.
kwb
PNW
I have three ~42in fans I got off the clearance rack at Lowe's. Installed on the premise that something is better than nothing.
Completely unfinished interior on a stick framed building. About 16ft off the floor.
On a hot day they help without blasting you with a hurricane. Depending on where in the shop only occasionally will they blow the welding gas away. When I run the heat I usually do keep them on to balance out things a bit.
For the $45 I spent on them I am pleased.
Brandon_oma#692
North West corner of Illinois
I haven't lived with these for long yet, but they seem pretty good for $200 each.
I was looking at those and the larger on the same listing. Do you feel a good breeze under them? What about further away like you are standing? I know I want something like this for the winter to get the warm air down. Just mixed reviews on all the big low speed for air movement for the summer.
RoadBeater
South Central, Ohio
I got the cheapest outdoor 60” fan at Home Depot, it came with a wall mount speed controller, at 10’ I can feel the breeze. I run it in summer and winter.
logical
Northern fringe of the Motor City Suburbs
Yes, they move a lot of air and are very quiet. They do have more than a few bad reviews for early death and poor customer service, but I am a risk taker...and lucky with things like this.
skippydoo
Sussex NJ
I put 4-60 inch canarm fan's in my 30x40. My ceiling is 13-15.5 ft (scissor trusses} The fan are almost 9000 cfm each and on high, they will move paper around. Only thing about the fan's is they are noisy no matter the speed and I had one go bad and they don't have a replacement , I have to replace all 4. Fan's were new November 2018
aggie113
San Antonio, TX
After looking at prices I went with some 10ft DC drive fans from HD. They have LEDs on the bottoms but only one of those really worked. It acts as a night light :)
18ft high with a 1ft(?) drop. You can still feel them but they are more for air circulation. I have ground fans for really cooling off if needed.
