Ceiling fan turns slow
skcj213
Southern Illinois
I have a question for the electrical geniuses in the group. I have a ceiling fan that turns slow and hums. When I say it turns slow I mean when on high it turns about what I would expect out of the medium setting. It is wired through a speed control on the wall. I suspected the speed control may be the problem, it was many years old, so I replaced it with no change. I have confirmed the fan is getting 120v. It has done this since it was purchased new. Does this sound like a bad capacitor?
Mongo68
Turn it on and spin it by hand. IF it stays going after the cap is bad...
yeldogt
What kind of fan and type of control ... the old hunter originals can't use a solid state control. Also -- make sure the fan is property set up for remote control. Most times this requires the onboard speed control to be bypassed .. through wiring or having it on high.
skcj213
Southern Illinois
I am not using a remote control, just a wall switch to control the speed. I think the switch was made by Lurton. The fan is set on high but turns at the same speed as it does on medium. I was going to change out the cap, they are cheap, to see if that was the problem. The cap in it has a rating of 5/6/6. I can’t find a 5/6/6. I found a 4.8/6/6. Will that work?
nadogail
Coronado, CA
I have been known to go into a shop that sells and services fans to “pick the thier
brains” and buy the right parts.
ddurrett896
VA
The new capacitor fixed it. 15 minutes and $5.50 well spent.
I've got a Minka Aire fan that came with a "remote" that is hardwired in place of the wall switch.
When I hit the "remote" wall switch, it doesn't matter if I hit 1 (low), 2 (medium) or 3 (high) - it only spins on low. Fan worked perfect for 5 years and recently had this happen.
Manufacture said I need a Capacitor ($7) and a receiver ($30). Do you think I just need the capacitor? Thanks!
Corndoggeh
Spray WD40 into the bearings on the motor, sometimes dust over the years gets in and gums it up enough to slow it down. I have to do it to mine every year because theyre only shielded bearings.
skcj213
Southern Illinois
Replacing the capacitor worked for me. They are cheap so I would give that a try first. there are many different capacitors with different ratings. Get the rating off your and find one that matches. I got mine from Amazon for about $5.50. Mine also hummed rather loudly, which it doesn't now. Does you fan make any noise?
