Ceiling fan with conduit?
dmcintosh
Smyrna, DE
So I decided to use surface mounted EMT to add outlets to the garage in the new house. My question is about mounting a ceiling fan. I’m planning to run my conduit from the wall control to the fan and then mount a 4” box that the fan ball hanger bracket will be mounted to. Any issues with this approach? Or a better way to do this? To seal the box I was going to use a flat cover with a 1/2” knock out in the middle, sandwiched between the box and the fan hanger. Thoughts?
Terry D
St. Louis, MO.
If you are talking about using a normal residential ceiling fan, just surface mount a octagon fan rated ceiling box. The fan bracket will mount to the 10/32 screws and the canopy will cover the box, no need to use a flat cover. You will be able to bring your conduit into the side of the box. Be sure to mount the box to something solid.
https://www.lowes.com/pd/RACO-1-Gan...rd-Ceiling-Fan-Ceiling-Electrical-Box/3129403
D
dmcintosh
Smyrna, DE
Got my conduit run yesterday. Thought I had some wire to get the fan connected and at least pull the wire to the switch, but no such luck. Maybe tomorrow once my supply house opens.
D
dmcintosh
Smyrna, DE
