Ceiling Fans
threeputt
Next to a very busy 4 lane
My son had two Ceiling Fans installed on his front porch a few years ago. It was done by a recommended electrician.
He tells me it has two separate switches for those fans. He said if they are both are running and he turns off the left fan first it will trip the breaker. Turning the right fan off first this does not happen.
The person that did this is no longer to be found and was wondering how he messed up in doing this install. Thanks for any info on this. I think if I knew exactly what was causing this I could fix it myself. THANKS. Tom
malibu101
Walnutport PA
That's a very strange problem. ?
Did it just start, or, has it happened since the install?
Being it's outside; Is there a GFCI involved? Not that a GFCI should matter.
T
threeputt
It has did this since the person installed them several years ago. He just always turns the right switch off first but asked me if I knew someone who might know where there problem is. Other than being annoyed by it there is not a problem unless someone other than him turns them off. I can check and see if a three way switch was installed. THANKS. Tom
T
threeputt
Yes, there is a ground fault circuit interrupter installed and he said the best he can remember it has always did this. THANKS. Tom
AntonLargiader
Charlottesville, VA
If he turns off the left fan, and the breaker trips, can he reset the breaker if the right fan is still on?
Also, assuming it is a GFCI breaker, can he tell if the breaker is tripping on GF or tripping on short circuit?
DSLTRK
PHELAN, CA
So you have the fans pulling off a GFI recep?
That's weird. I guess that could cause it, esp with cheapo china fans with bonded neutrals. Did you check the junction boxes to make sure a wire cap hasn't loosened?
I thought the problem could be you have each fan on a different hot, and the left fan switch is back-feeding 240V through the right fan. Seen that happen before.:lol:
These are single pole switches?
Socket Pounder
Santa Clarita
Similar situation came up in conversation recently and one of the switches was the wrong type and I think it was wired backwards to boot. Sorry, can't remember details but that might put you on the right track. But yeah, pull the switches and make sure they are right.
PT Doc
Time to pull out both switches and check for proper wiring. Then check wiring at the ceiling fans. Do they have lights and have a 4th wire?
T
threeputt
Sorry I have not posted back on how things went with this electrical problem but my son has not checked what I told him to yet. He is over loaded at work and just not had time to check this. I will get on him because of me posting about what the problem might be. THANKS to all and when I get him to check this I will post back. Tom
If it was a single pole switch, no way it can be wired backwards as there is no difference between the 2 screws.
