Good to know about the rolled insulation trapping dirt. That was my other option if I don't leave the trusses exposed. Spray foam is way too expensive around here. I talked to a guy that spray foams in my area and he said figure around $10k for the roof only, that was for 2in. Building is 24x36, that's insane in my opinion, I'm doing all the work. I had the Amish put up the building and I hired guys to pour the crete after I graded and prepped it.
I don't want the metal liner panel on the ceiling or walls, I think it looks too commercial. This will be my man cave/shop/storage area. I plan on keeping it fairly clean in there. I'm trying to find the truss spec sheet so I know what I can hang from the trusses as far as weight. Trusses are 4' oc, my thought was to used the 4' white vinyl back rolled insulation, tape the seams and use banding. That way I'd keep the weight hanging off the trusses minimal.
The exposed trusses was something i saw that looked cool, I figured try that route because it would give me that design feature bit also elimate the ceiling covering.
What other options are there for light weight ceilings other than metal I'm open to ideas.
