Ceiling LED wiring
jarhead
Colorado, near Morrison
My detached garage currently has outlets on the ceiling for lights with corded plugs.
Since i am hoping to turn my ceiling into a vaulted space (after consulting an engineer) I want to rewire without outlets.
I will be putting in LED strip lights without corded plugs. what style of electrical box is used and what type of cover goes on it. It seems to me the strip lights are much narrower than the electrical boxes so i want the box to be covered.
I am going to run three separate switches so i can only turn on the amount of light needed.
I'm probably overthinking this but i am have a brain fart moment here.
Thanks, Joe
The proposed lights
J
jarhead
Thats how i did it in my last shop but these new style strip lights are skinnier than the box.
Roert42
NE Penn
I would keep the existing plug setup. When I installed LED lights in my garage I mounted regular boxes, cut off the plugs, and hard wired the lamps. I regret cheeping out on the outlets now. Would be nice to be able to mount a could drop lights or something from ceiling.
Any rate. If you do cut the plugs off the wires are probably stranded. So, don't forget to tin the wires before you wire nut them so they twist together well and you get a good connection.
J
jarhead
I'm trying to avoid using GFCI breakers for ceiling outlets.
As I understand it lights plugged into receptacles on the ceiling require GFCI breaks. I could be wrong on that requirement.
pbon
I think those cheap Amazon LEDs have a plug that goes in a regular outlet. Then you can string more to that light using the 4’ connector cords, which will be hanging loosely unless you secure them. I use similar but 4’ cheap Amazon LEDs in my garage basement and attic. For the basement, I ran wire for outlets in 4 places since my light layout required 8 lights and the distances and light placement did not allow stringing more than 2 together.
For the attic, I put one outlet in the center and ran 2 lights off of each receptacle.
For the shop on the first floor and storage on the second floor, I hard wired higher quality 4’ LED strip lights with diffusers. I have ceilings so I did not need boxes for most of them. The fixture can serve as a box. For a couple that I dropped down from the ceiling so the garage door rails would not block them, I installed boxes and ran a short piece of conduit down to the light.
hobie18
Stick with one side longer. Runs on outer edge. Other side presses button. And if you get frustrated, pinata.
murd
Cape Breton, Canada
I put those into my garage, they're great lights. I bought a 10 pack, but only put 8 up. Nice even light. I did put 3 outlets in the ceiling, then ran the jumpers to the ones on the side. I'm going to probably zip tie the little cords when I'm done drywalling.
I'll try and get a photo of them.
PCustoms
VT
Looks like there's a beare lead to wire into a box. You'll need a cable gland.
Fair warning: those look a lot like what a friend used in his shop, in the cold the light shrinks lengthwise and looses contact with the next strip. He has a long stick to shove the joint back together
Bert_
NW Iowa
Thanks, Joe
The proposed lights
For those lights, stick with a plug. That way WHEN you have to replace them it will be easier. Those are low quality lights.
sparky 1971
Central Iowa
You can avoid the GFCI requirement by using twist lock cord and plug.
Twist locks can get pricey, but those lights are going to fail much sooner than later and will have to be swapped out. I installed a bunch of similar, if not the same, customer supplied lights last summer and all I can say is good luck. A GFCI is much more cost friendly.
wfopete
Somewhere North of Dover, AR
I have those same lights install in my barn. The switches are **** and will overheat/fail. Heed the warning about how many you can have (4) going on one loop. Error on the low side of 3 or even 2. Mine have been in for a year and have been reliable. I used Wago style wire connector to connect with my hardwired J-boxes.
mm08822
That website has all of the earmarks of Chinese ****. Refund sure, after you return the POS to China. Spare yourself the frustration and buy Lithonia, Cooper, etc., linear fluorescents.
Roert42
NE Penn
Second that. If you want to GFCI the outlets, use a GFCI breaker for the circuit.
or, install a GFCI breaker within reach and run the rest of the outlets on the load side of the circuit breaker, so they are all covered under on.
When I did LED lights in my shop, I bought some from the local hardware store that look a bit like this. They hand from the rafters with the outlet mounted on the rafter. Then the cord runs up the chain.
I have a separate box for each lamp.
Bert_
NW Iowa
Thanks all. i will put in outlets.
Suggestions for a different LED light?
Anything from a major brand.
For a low cost but good quality option I have been salvaging 8' fluorescent strip lights and using RAB 5500 led lumen bulbs. Those bulbs used to be $20 each, now they are about $30. Still a good deal. You get an 11000 lumen strip for $60 and it has replaceable bulbs.
You can do the same thing with 4' strips. Common 4' led tubes aren't as bright but there are some 3000 lm ones out there.
