Homer14
Hi,
I'm planning to put a ceiling up in my barn now that spring is coming around. I have some questions and welcome input from those experienced.
I'm pretty set on going white steel sheeting as it is light weight, bright for light reflection, and will hold insulation fine with my 2' spread trusses. so with white steel sheeting assumed I have general questions below. The sheeting will be going the length of the 40' direction to be perpendicular with trusses for nailing or screwing.
1. Screws. They will be into the wood truss. What kind and size of screws. Screw into every truss or every 4'?
2. Sheet lengths. I see places like Menards sells precut sheets of 8,10,12', etc. If i did pre-cut id had to go 12' i suppose to be safe and have a little extra in case right? Or do I go with the option length of my choice (e.g. 2x21' or 3x14' per sheet column hung)? I believe the width is standard like 36" or something.
3. Ceiling before walls? I'm anxious to get my ceiling wiring done for my lights, and get lights up! Due to that i need to put the ceiling up. so i can hang lights. Is it ok to do the ceiling first and the walls second and just somehow seal stuff in the upper edges later?
4. Plastic vapor barrier. What mill or type of vapor barrier should i put up against the trusses before the sheeting gets screwed in? Above the barrier will be insulation batts or spray eventually.
5. any suggested vendors for the sheeting such as menards, lowes, home depot, online somewhere, someone that prints sheets, etc?
6. lift mechanisms. ive seen some list devices for rent at places like menards. im sure they will help a bunch. what type of lift mechanism should i rent, build, or buy? just a standard drywall lift or something? my barn is packed (my fault) so ill be moving **** around, doh.
thanks all for your input. if i need to add details please let me know.
-Homer
-Homer
