Ceiling options
Bradbilt
Gilbert PA
The building went up in April, the floor was poured last month.
Now working on the inside...
I found a "system" for the ceiling and the top 8' of the walls.(16' total wall height)
Called Tryply Ceilings.
From their Facbok page...
"What’s a triply ceiling? A poly fabric material supported by polyester banding and painted wood trim. And typically a layer of insulation gets blown on top to keep your building climate controlled. "
It is basically a very tightly woven quality tarp for lack of a better term.
The process of install is attach the "tarp" to the bottom of rafters or truss'
Then 1/2" wide nylon banding that runs perpendicular to the truss' every 12-14"
then put 1-1/2"x 1/2 wood strips down that get stapled to the length of the bottom of the truss.
Then blow in insulation can be blown in on top of it.
I got a quote for my 4800sq/ft building and i thought it was very reasonable
Ceiling material is $3337
R38 insulation in the 2240sq/ft shop + R20 insulation over the 2560sq/ft storage for $2944
Does anyone have any idea if this is a good price? A good product? What it would cost to have it done in tin?
Their claim is a cost saving compared to tin. It absorbs sound apposed to tin reflecting it and echoing in the garage. It is Not fire proof, but neither is the tin(metal gets hot and wood truss catch fire). They did have a customer that had a fire, the fabric melted and the insulation fell down and extinguished the fire
Suggestion, comments concern?
Their FB page. They do not have a web page
https://www.facebook.com/MidAtlanticTriplyCeilings/
Dragfluid
Pillager, MN
Sounds like a **** shoot to me. Besides, in your heating zone, you should have more than R38 up there. More like R60, and that stuff may not support it. Plus I don't like the way that it's flammable.
Bradbilt
Gilbert PA
LOL R60!!!!!!!! Yeah sure. I dont live in the arctic
Also, nobody said it is flammable. Just not Flame retardant
As for its strength. he gave me samples. Two men pulling their hardest will not rip it.
Also he told me a story about a insulation install. The spray guy was WALKING on the fabric, they could see his footprints from underneath and that was on 8' spacing. He didn't rip it or fall thru. Obviously he does not promote walking on it
Bradbilt
Gilbert PA
Looks sharp. I wonder how they get it so tight?
I guess the banding get anchored to the walls and they have some tool to pull that tight. As for the fabric, i think they just have guys working and pulling it tight as they staple it up
Dragfluid
Pillager, MN
No, you don't live in the Arctic. You also don't live in the tropics. You live in PA, where the MINIMUM R value is R-38. Why would you want the minimum? Don't you want to be comfortable?
You're building something wonderful here. You want to do it right the first time.
LS6 Tommy
Northern NJ
X2 on the flammability issue. Even if something is rated as flame retardant, it's still flammable. Flame resistant is non flammable.
Tommy
Bradbilt
Gilbert PA
I dont live in the building. R38 is at least twice what is in my house. As for minimum allowable amount, Code is R24 So I am doing 1.5 times the minimum code
Bradbilt
Gilbert PA
Tommy
Nobody said it was flame resistant either. The ONLY thing that is even remotely conducive for a garage ceiling that is flame resistant is sheet rock. And I am not framing out the entire ceiling to hang sheetrock
LS6 Tommy
Northern NJ
I think you missed my point. You said "Also, nobody said it is flammable. Just not Flame retardant". I was only clarifying that by definition, not being flame retardant or flame resistant means it IS flammable. :thumbup:
Tommy
NUTTSGT
Northern Central Ohio
I can tell from experience which one is going to last longer in a fire if that fabric stuff is polyester. I'll take metal siding all day long over a fabric ceiling.
How's the resistance to UV rays ? How about having them send you a sq ft sample of the stuff ?
MushCreek
Upstate South Carolina
My ceilings are 12'. Other than the outside chance of an electrical failure, by the time the flames reach my ceiling, the shop is gone anyway. Still, I'm probably going to go with metal. I prefer to DIY.
ddawg16
S. California
Rule of thumb for 'bleeding edge' technology.....don't be one of the first ones to try it.
I can see why it looks attractive....it appears to solve a lot of problems.
I didn't see anything about moisture barriers....resistance to mold?
Bradbilt
Gilbert PA
I have a sample of the stuff that is where I said 2 men cant pull it apart
Bradbilt
Gilbert PA
Mine are 16' so I would be in even more trouble
I'm juts trying to weight the advantages of both. I love the idea of the sound absorption, because right now it echoes really bad.
Agreed, but it is not new technology. it has been around for 30+ years
Is sheetrock a moisture barrier?
