MayhemMOORE
- Joined
- Jun 8, 2013
- Messages
- 16
Ok, not garage related, but in a house we just purchased on Friday. Before I can begin work in the garage I have to get the house up to par for the wife. I am replacing a ceiling fan in our living room and I am a bit confused on the wiring coming from my switches. I may just be overtired but I am not understanding what they did. Coming from the ceiling I have a red (constant hot, not switch controlled), black (switched hot) neutral and ground. The red I get, I can use the fan independent of switches if I so choose. The black is my switched hot; there is a switch on either side of the room that will control the black, simple enough and I get how two way switches work and using just the 2 it works as it should. Now this is where I am getting lost. On one of the switchplates there is a 3rd switch that I could not figure out what it did....until I took down the fan; this is a single pole switch that also controls the black to the fan. It will energize the hot regardless of the position of the other two, two way switches, basically overriding them and making them useless. Is there some reason for this that I am overlooking, because to me it just seems like a huge pain since if that switch is on then the switch across the room becomes useless. I don't know why someone would run three switches to one fixture all in the same room, one of which overrides the shutoff feature of the other two. I may just disconnect the random switch unless there is some valid reason to have it.
