ultgar
- Location
- Emerson, NJ
- Price
- $2,995
Cemb C75 Tire Balancer - Online video . Classic balancer, never used. Purchased new in 2008 (its now obviously outside the original warranty period). List price at the time was approx $10,000. CEMB USA is still in Gainesville, GA
Features include.......
- 15" color monitor (CRT)
- Fully automatic cycle
- Self diagnostis and self calibration
- Alloy wheel function with USER FRIENDLY split and hidden weight program
- DIRECT WEIGHT placement program
- Automatic input of distance, diameter & width SONAR (Cemb Patent) (3D)
- Automatic optimization alert, two operator function
- Manual brake pedal for placement of weights.
- Accurate to one gram
- QUICK RELEASE wing nut and 42" wheel guard are standard.
- Standard power supply: 115-230 volt single phase 50/60 Hz
- Max absorbed power: 1100 watts
- Packing dimensions: 152x105x183 h cm
- Rim diameter: 10” · 30” or 265 · 765 mm
- Max. wheel weight: 75 Kg
- Balancing speed: 180 rpm
- Gross weight: C75 (with cone adapter, pliers and wheel guard) 161 Kg
- Balancing accuracy: ± 0.5 grams
- Rim width: 1,5” · 20” or 40 · 510 mm
- Max. outside wheel diameter: 1300 mm (1060 mm with lowered wheel guard)
- Cycle time: 6 seconds
- Gross weight C75 SE (with cone adapter, pliers and wheel guard): 176 Kg
- Spindle shaft: ˜ 40 mm
