Center Punch Recommendations
crazyjim30
At least 10 years ago, I bought a General center punch. It was one of the worst tools I've ever bought. The point was bent right out of the package. Returned it for a replacement, and the "chrome" on the replacement delaminated within six months.
Buy a Starrett. Buy once, cry once. Sure, it's 40-50 bucks, but your grandkids will be using it 50 years from now.
Sent from my Pixel XL using Tapatalk
tym
Home Depot has Mayhew...just get that
I'd second this; the HD Mayhew is pretty inexpensive too.
I've tried Dasco punches; they're a good example of crappy Made in USA tools (very soft steel).
Tinner
N.E. Wisconsin
d.mcfarland
Western PA
Between the Huskey at HD for $15, the General Tools at Lowes for $10, and the HF for $4,
any recommendations? I dont mind paying $15 if the value is better than the others.
thanks, I'll try the Huskey, I can't justify the Starrett as a home DIYer. I can always return and upgrade if its bad.
WTF??
Asks for suggestions then doesn't even wait 30 mins and already has mind made up.
Go ahead ... buy the Husky (not Huskey) and regret it after the first time using it. Or pick up the Mayhew right beside it on the shelf and be at least a little more pleased.
With that said I have a Tekton automatic center punch for like $5 off of Amazon that works perfectly ok and if it has a problem a simple call or email will get the problem fixed. Great customer service from them.
tym
I sure can! I won't use anything else. They're excellent punches.
+1. Usually people don't consider that the "expensive" tool you only have to buy once may wind up costing less than a cheapo tool that may need to be replaced multiple times.
NeuseRvrRat
Starter taps with the pointed end work great. Lots of industrial type jobs expect you to bring your own punches, but will hand out taps and drills from the storeroom as consumables.
Coach James
Sandhills of North Carolina
OP, I have a couple different brands of automatic center punches, one is the general you linked in your original post and I can't remember the brand of the other. Both have work ok, but I find myself going back to a regular center punch hand hammer more and more.
Are you set on an auto punch?
Coach
AmericanMechanic
What is the reason to use this style versus the simple steel punch you tap with a hammer? Work on delicate items?
Matt Matt
Ontario
I’ve been working with punches for many years. Centre punches, threw punches & form punches.
A auto punch is a piece of junk. It’s just a gimmick for 13yr olds
When you’re done with everybody sending you links to ****, just p.m. me and I’ll send you a high-speed steel tool blank.
ptgarcia
Alta Loma, CA
Starrett. Santa brought me one this year at Christmas and it is very nice, much better than the generic China special. It's my first Starrett tool and hopefully not my last.
Sent from my SM-N910T using Tapatalk
larry_g
oregon
I'm with Matt Matt here. I've never been able to get any kind of precision from an automatic punch. If your doing layout with a yard stick then cutting the hole with a torch then ok. If your doing layout with height gauges and granite surface plates then the autopunch is not going to get the job done. And yes I do own a couple of Starretts as well as a couple of off brands. Over the years I've had failures with all brands. Sometimes the manual way is the better way.
lg
no neat sig line
lg
no neat sig line
Sears Gilera
The C.H., OH
Starrett is the gold standard. Have used mine for over 7 years and no problems. The Harbor Freight units work for a few months then the tip dulls to the point of uselessness.
Merch1
After 30 years as a steel fabricator, I find myself reaching more often than not for the auto punch for accuracy. Then a good wallop with the manual to finish.
OccupantRJ
Eastern North Carolina
My dad was a finish carpenter, so I acquired most of his tools. Some of his older nail sets were not in good shape on the tip, so I ground them for use as a center punch. I was a machinist, toolmaker, and repair, and these punches have been every bit as good as my Starrets have. A cheap way out if you have any old school nail set punches.
J
joe_pinehill1
Northern Virginia
WTF??
Sorry I needed a punch yesterday, and was looking for a quick thumbs up or down on the three before buying one. I'm not a machinist, I was laying out holes in wood. Happy New Year.
txlonghorn1989
I tried Dasco punches from HD last year. They got returned after first use. I ended up buying a set of Starrett off the big auction site. I haven't had an occasion to use them yet.
