kooldino
So unfortunately, I'll sometimes encounter situations where I need to drill out a bolt. I use a punch and try to center things the best I can, but it usually doesn't end up dead center.
Is there some kind of centering tool or some kind of trick I could use to make sure I start drilling dead center on the broken bolt?
I had a thought of using some sort of "sleeve" to go around the bolt and using the largest bit I could fit inside of the sleeve to start the hole. This way, the tip would cut in and should give me a good center hole. Of course, that's easier said than done.
Any other suggestions?
