MEDTECH
I have a heil/ICP unit that is 25 yrs old and part of a forced air system. 2 days ago, the unit stopped working; no compressor, no fan and no noise or humming can be heard from the outside unit. I have no experience with HVAC but I tried the easiest remedy which was to replace the dual capacitor, carefully checked my connections to HERM, FAN, COM and no luck. Had a handy friend take a look and he tested voltages on the contactor and all values are good. The contactors plunger had to be pressed in and the compressor did come on but not the fan. Coolant line was cold so that seems ok. Just curious while I wait for my tech to come, can this be a bad fan motor? Hi or low pressure switch engaged? Just trying to learn what else can cause the fan not to spin. Even replaced thermostat batteries to rule that out, too. Thanks for your insight. Also checked the breakers, always replace filters every 3mos or less, condensate drain was discharging as it should, etc.
