Nightshift
Guys, I've been reading up on the flooring threads for those of you who have put ceramic/porcelain tile in the garage, but so far I haven't concluded if this is a wise choice in northern climates where the floor will go thru freeze/thaw cycles each winter.
I'm planning to do my garage floor in southern Ontario most likely with a porcelain tile I can get for under $0.75/sqft. Not as cheap as Jack Olsen's deal, but still reasonable in my view. I've laid ceramic tile before in a kitchen and bathroom, so I understand the process. I'm planning to keep the grout lines narrow (ie 1/8") and use a dark grout as I don't want to be bothered sealing and re-sealing grout every year.
My only question really is whether ceramic tiles are a durable choice in northern climates? From the threads of members here who have installed ceramics ... are any of you in northern areas, and what has you experience with freeze/thaw cycles been with the tiles? Many members don't show their location, so I can't tell if you deal with winter or not. Thanks in advance for you comments. Cheers, Bill
