logical
Kinda sorta half right. Pressure and volume are indirectly proportional but that is a relationship that assumes a constand mass of air that you are increasing and decreasing the pressure by changing the size of the container it is in (volume). Once you are talking about cfm you are talking about a machine's ability to supply a quantity of air at a given pressure. Think of "cfm at 90 psi" as "how much air can I consume per minute at 90 psi and not ever run out of supply as long as the motor is running".Pressure and Volume are indirectly proportional. As Pressure increases, Volume decreases and vise versa. If a compressor states ACFM(Actual CFM) 10.6 at 90 and 12.4 at 40. It's real simple. It means it will deliver 12.4 ACFM at 40 psi continuous and 10.6 ACFM at 90 psi continuous. If you have any doubt whatsoever, put a flow meter on the line and measure it. These raw equasions being put forth here are lacking as they do not account for your local Atmospheric pressure and humidity factors to start with. Those equasions are designed for laboratory use. Some of you guys have garages so clean they could be labs, but that's another story.![]()
I can't believe (well, yes I can actually) how many people know all these formulas but have no clue when they apply or how to apply them.
