Chain Saw Recommendation
garandman
Boston MA / Mt Sunapee NH
I had a Farm Boss MS271 that I gave to my nephew when I purchased a MS362 Pro Saw with a 20" blade..then put a 24" blade on it for some larger jobs.....the Pro Saw is a Hoss, but the Farm Boss is no slouch either....it's a fine saw....
Still happy?
We have an MS271 w/ 18” bar and its worked really well. But doing more cutting and the MS362 is a couple pounds lighter, more powerful (59cc versus 50cc) and Pro features and longevity.
We also have a MS462 we bought used for felling some larger trees. I’s awesome but all-day with it wears me out.
jonshonda
Wisconsin
I am glad I didn't follow most of the GJ advice to buy a pro saw. Ended up buying a MS250 because we just had three good sized oaks dropped in our yard, and I didn't feel like paying $500 for clean up. So I will be using the saw for fire wood work (not heating a house, we go through half a cord a year) and regret paying as much as I did for how much I will end up using it.
Cutting up 20" red oak I couldn't just lean on the saw and expect it to not bog down, but it make plenty of saw dust in short order. Hate to be the guy on the other shoulder telling you not to spend your money, but Stihl makes a damn good saw and you don't need to buy PRO to get good products from them.
showags
Twin Cities, MN
I have a Stihl Farmboss and have had great luck with it for over 10 years. I recently bought a 20V Dewalt as we seem to lose a limb per storm/wind gust and got sick of bringing out the Stihl for 10 minutes work. I was hesitant, but gave it a shot. The Dewalt has worked flawlessly and is much easier to use with one hand for quick clean up jobs. If I had to only choose one saw for the limited work I do around the property, I would probably go back in time and by the Stihl top handle instead of the Farmboss. For the few times I needed something bigger, I could borrow one, but thinking back, I believe there would only be one time that would be the case that a top handle would not have done the trick. It's all about what you do the majority of the time. With that said, you could buy a Farmboss and a cordless for less than the price of a pro saw. And yes, I feel less manly using a battery chainsaw, but the thing works.
garandman
Haven’t bought a battery chain saw yet. We have an 18V DeWalt reciprocating Saw. We use it with a demolition blade for trimming stumps and other wood near the ground.
eschoendorff
I’ve done that too. Takes a little longer with a reciprocating saw, even with a demolition blade, but it works.
bradn
I too have 20+ acres,, you REALLY need 2 saws, 1 for walking, limbing, trimming, etc and one for "Cutting" trees down and cutting the main trunk into fire wood.
I run a Sthil farm Boss 20" for the heavy stuff, and a small echo for the light stuff.
The echo is 20+ years old and I am replacing it with a light weight Sthil in 12" bar (400-500)
I agree you need two saws. I have an ms290 that i have had over 10 year and just picked up an ms150 last year. Wish I had done it sooner. I picked the 290 up used and have never had to do much to it other than a spark plug chains and a new bar. Its been very reliable. I Avoid ethanol and mix up 5 gallons with stabil for all my 2 strokes every spring. That usually last me all summer and I dont have to worry about fuel going bad with the stabil in it.
Mr Ratchet
I have a Farm Boss (MS 290) with a 20" bar and 3/8 yellow link chain. I can't even keep track on how many trees this thing has fell, limbed, and bucked over the years. This is bar #2 in the pic and needs another one now. Not sure how many chains and sprockets I've gone through. I cut pine, poplar, maple, oak, beech, and cherry the most. Diameters from 6" to 24" most often.
Husky and Echo in similar models are good choices as well.
Y00PER
Keweenaw Peninsula, MI
I had an 18" 42cc Poulan for 10 years. Made all of my winters wood with it. About a year ago I bought a 20" 50cc Craftsman that's made by Husqvarna. I only used it last summer to make wood for this winter, but what an improvement over that Poulan!
Den69rs96
Central MA
The ms250 is a good saw and perfect for your needs. I have one, plus a ms361, and a ms046. I use the 250 the most for yard clean up. Its a great limbing saw because its light and has decent power.
The ms250 is the only saw I bought new. After a year or so, I realized I needed a bigger saw and bought a used 361 with no bar for 300 bucks. The 361 is my favorite saw. I bought my 046 as a project saw because I was bored over the winter a few years back. The 046 is just a beast.
If I had to keep only one, I'd keep the 361. Its a pro saw with a lot of interchangeable parts with Stihl's other pro saws. I really like the power to weight ratio plus and range of bars that fit it.
6PTsocket
I can't comment on the two saw models you are considering, but Stihl is usually a good bet on saws. There are other good brands too, though.
Unless you have a source for ethanol-free gas, I highly recommend buying the premixed fuel. It's premixed on the fuel/oil ratio (no agonizing over those few drops left in the oil container that will never come out), and usually includes fuel stabilizer (one less thing for you to worry about). Just make sure any cans you get haven't already been opened. If you can find date codes on the cans, get the newest possible.
I'm about as DIY as anyone, but this is one place where I yield to convenience
After using pump gas with Stabil and still having to take apart my Husqvarna carb, I am using ethanol free premix from now on. It is expensive but the alternative is worse. I would mix the ethanol free and the oil if it saves you a little but no more ethanol.
CR888
For saw recommendations, I always advise a Farm Boss, as long as its a Farm boss with the genuine Farm Boss sticker your good to go! Being the Farm Boss is pretty awesome, you want a big arm & blade. The Wood Boss is good for smaller blades but big boys usually go for the big bladed Farm Boss. The ultimate wood be a long bladed Farm Boss Magnum, I haven't found one yet but one day I hope too. Trees wood just fall at the sight of it! Also you can reduce the weight of the saw by removing the chain brake handle, first mod I do to em as you only need one handle. The awesome high output ninja style power of the Farm Boss with extra long cutty bar blade won't be tamed by a plastic handle brake in any case. Though if your safety minded its not the best idea. Be safe. I like turtles too.
sdeeter19555
backyard
Stabil is your problem...use Startron, much better additive. I have equipment with two year old gas that will fire right up...
I run ethanol gasoline in everything, finding ethanol-free was impossible until recently.
CR888
What's different about Startron compared to Stabil? I thought they were essentially the same thing...alcohol that absorbs water. Love to know the answer though.
sdeeter19555
backyard
I don't know what the difference is other than one works and the other doesn't based on experience. Had issues with Stabil, switched to Startron and no more issues. I don't think Stabil works as well as it once did...
CR888
That's interesting, I don't use stabilizer's for the simple reason I get E-free gas easily & just buy it in small batches to keep the gas fresh. I find small 2-strokes appreciate fresh fuel, anything that gets to 3+ weeks gets poured into the 4-stroke mower...it loves old flat gas. The sooner EPA/gov authorities wake up to this ethanol scam, the better.
C
Coach James
Sandhills of North Carolina
Well, it's been about a year since I bought the ms250 so I thought I would post an update:
The saw works fine and no problems. That's about it.
I get ethanol free gas from a station near my house, but only mix a gallon at a time. Most of my cutting is in large batches, not continuous small amounts. It starts easy, I keep the chain out of the dirt, clean the saw after each use, keep the chain sharp and it keeping doing what I want it to do.
I am thinking of getting a shorter bar to make limbing work easier, but I will have to get out a crow bar and pry the wallet open to do so.
Is there a significant difference between Stihl bars and Oregon ones?
Coach
sdeeter19555
backyard
I run Oregon and Silver Streak bars on my MS391...Oregon seems on par with Stihl.
I bought a smaller cheaper saw for limbing...found a guy selling refurbished Homelite for less than I could buy a bar and chain for the Stihl. I've had it six years now, the only thing I've done to it (Homelite) is fuel line, coil, and the tensioner nut.
I've spent nothing on the Stihl except for spare bars and chains...I have a 25 inch bar and three chains hanging on the wall that I've never used.
It gave me a second saw in the event I got into trouble with one or the other.
upper_tanker
My dad has had a Stihl MS-280 with an 18" bar for YEARS. Up until about 2 years ago, He'd have a guy drop him off 8' pieces of wood so I could cut/split/stack it. He used to burn about 20 f/c per year at his shop.
In tandem, I'd also use a little 12" Redmax saw if I had to cut a lot of smaller wood.
We've had zero issues with either saw. I've probably cut at least 1000 f/c worth of wood in my time, all with these two saws. Neither of them have gotten anything more than a tune up, a bar replacement or two, and chains. We store them all winter and sometimes don't even empty the gas out of them.
I didn't read through this entire thread, but my biggest recommendation to you is to learn good saw practices. Don't use extra force on the saw to cut wood. If you can't just lay the saw on the wood and have the saw's weight do the cutting, then it's time to sharpen or replace the chain. That "stupid" advice that my grandpa instilled on me at a young age has given me the knowledge to be able to cut quite a bit of wood before I even need to think about changing the chain.
Also, if you respect chainsaws (like EVERYBODY should) and are comfortable with your ability to use them, you can get a rapid super chain. These chains are PHENOMENAL when it comes to making quick cuts with minimal effort.
To me, like many other things, buying a chainsaw is a "buy once, cry once" event. You'll probably pay more for a good, reliable saw at first, but you'll save in the long run by not constantly having to work on it or pay somebody to work on it.
redwrench60
East Tennessee
I don’t have anything constructive to add or anything to say that hasn’t been said except that any chainsaw thread needs lots of pics of chainsaws in their natural habitat. I’m pretty sure there’s scripture to back me up on this. Here’s my MS 461 gassed up, tensioned and ready to go on a perfect East Tennessee spring day.
Davefr
OR
A chainsaw is rarely a "buy once, cry once" event. After the one saw plan you'll decide you want a two saw plan, then a three saw plan and on it goes.
Two is really bare minimum because you never know when one will get pinched in a cut.
Kenskip1
Missouri
i WOULD MAKE A TRIP TO YOUTUBE AND see what people say about the Echo 590. A fantastic saw at a lower cost than Stihl,or Husky.Home Depot sells them and a warranty goes with it.Stihl, is way overpriced. I now have two Echo's and they beat the competition hands down. CS 550 and CS 490. Both fantastic saw.
^&right
Indiana
Another vote for the Stihl MS290 20" bar. Mine has cut a LOT of wood and fell its fair share of trees.
