Chain Storage Ideas for a Trailer
ArtisanFarms
Phelps, NY
I have a 14’ Deck over style equipment trailer that I share with three of my sons who live close by. It rotates between our homes and the farm depending upon who is using it. Consequently, I like to keep an assortment of straps, chains and binders on it so that it is ready for whatever is thrown at it.
I keep the binders and straps in a toolbox mounted near the tongue of the trailer and am looking for a good way to store the chains without having it become a tangled mess.
How do you store chains on your trailers in a way that makes it easy to check that they are all there and that doesn’t result in them getting tangled.
JeepYJ
Use some square or rectangular tubing to make a “box” by welding some scraps across one open end to be the bottom (leave openings for rain and debris to fall through. At the top you can cut some notches for the hooks. Easy enough to add some pieces and a padlock for some extra security.
To keep the chains from tangling hold the hooks together and fold the chain in half. Put that end in the box first and lower the rest of the chain into the box.
Zewnten
Heavy duty expanded steel sitting on cross members. Only put one hook on the chain, binder grabs the other side. Chains always tangle but this way the chain can pull through the mess.
djbmw
Ottawa, Ontario, Canada
Amazon has a decent one that also has a locking cover over it:
"Mytee Products 24" Trailer Chain Holder with Aluminum Metal"
Have you looked at how some of the flat bed/tow truck/fire truck/long haulers carry theirs and borrowed some ideas?
bwringer
Indianapolis
Each chain goes into its own container. I've seen everything from ice cream buckets to old Tupperware to coffee cans used for this.
If they're exposed, punch some holes in the bottom so water can drain. Everything will still become a rusty mess, but at least each chain will only be tangled with itself.
That said, I grew up on a farm, but one with highly questionable maintenance practices. So that is maybe a really, really bad idea.
