Chain storage in oil container
1320
Arizona
Maybe I'm sheltered, but maybe some of you haven't seen this like I hadn't.
Recently, a group of my friends and I took trucks and trailers to go recover some dead vehicles and one of my friends had his chains stored and transported in an empty 1 gallon oil container. It works particularly well for taking the Chain somewhere.
Containers with a top handle are probably more appropriate for this application than the rear handled variety. 15' of 3/8" Chain fits well, probably 20' of 5/16" is fine. I wouldn't put 1/2" Chain in one unless it's particularly short.
If someone steps on the container or you run it over or something, you're hardly out anything. Not a lot of rain or moisture in the air where I am, so I can't attest to the effects on your chain if you live in rustville.
I thought it was clever and have used it for a while now and been happy with the results.
quickfarms
Southern California
Because craftsman stoped making or selling the 22” truck boxes.
before that I put a chain and binder in each box and now I have been switching to the oil containers.
I let them drip into the oil jar before I use them
NUTTSGT
Northern Central Ohio
Yep, did a few times before myself when I had a box in the back of the truck.
I've seen guys tip an "empty" oil qt bottle in them for draining the last bit out when changing oil. It does a decent job on oiling the chain.
Sumboodie
AK
Why would you want oil all over a chain?
I'd much rather deal with surface rust than a chain goopy with dust and dirt mixed with oil.
Been working on a piece equipment this last week that was used to spread salt.
It's a nassty mess of grease, oil, dirt and rust.
NUTTSGT
Some people prefer to have their chains like that I guess.
rayra
Escaped from Los Angeles
RR Buildings YouTube channel uses this trick for the chains they use to true their post-frame buildings. And they hang the hook ends in the mouth of the container.
It's a pretty handy method.
5gal buckets work nice as well, although they get pretty heavy
eta iirc they use big-mouthed containers like cat litter and other things.
bassJAM
Cincinnati, OH
Might have to try that. I have mine in one of those yellow 4gal kitty litter square pails, but there's 4 or 5 chains in it and it sure is heavy
kbs2244
I have been doing it for years cut the side out of a one gal jug makes the car trunk neater
one chain per jug and a pair of gloves per jug plus one of those frame slots to grab hook adaptors
lilredex
Toronto
Been keeping my chains in heavy duty plastic bags for fifty years, the kind that sand comes in from the lumber yard.
i4ni
Thanks, I'd seen that before but kinda forgot about it. I've been organizing alot here lately so I'm gonna get right on that one.:beer:
i4ni
It's not real practical but dragging logs or brush will shine up a nasty chain pretty quick lol.
Bretny
Dutchess county NY
I would rather a rusty chain over a oily one any day. How ever most of mine are yellow zink and with 10-12yrs of use dragging logs or binding things down dont show much if any rust.
Two Speed
Ontario Canada
If you have that much oil left in your oil containers that you end up with a goopy or nasty chain, you need to drain them better. =-)
