Inabox85
I put up chair rail at home the other day. I mad a video about it.
Don't be mad, your trim looks nice. Coping takes practice but, it's far superior to mitering. 2 tips. 1) 45 the end of the molding as if you were mitering the corner and the cut line is the line to follow with the coping saw. 2) Cope the molding and check the fit before you cut it to length.
Another trick is to tip the work piece when cutting the miter. By this I mean if the case is proud of the wall lift the front of the work piece slightly. Lift the back slightly if the case is recessed slightly.
