shamrock12
I've been checking out Champion air compressor but am confused by several of their pump choices. There are "RV" series pump in their "Centurion II" line, "VP" series pump in their "Value Plus" line, "R" and "PL" series pumps in their "R-series" and "PL-series" lines.
From what I have seen, it appear that "PL" pump is top of the line as it is pressure lubricated. Next to that would be the "R" pump which I believe is very similar to PL pump but instead is splash lubricated.
Then there are "RV" and "VP" pumps that I assume are lower values but seriously, I couldn't tell the difference from the above. Can anyone pitch in and explain those pumps?
Also, I see that two different "R" pumps are offered for their 7.5hp R-series unit, with one being R-15B and the other R-30D. The latter appears to have higher CFM rating but does that mean the motor would be working harder than the earlier one? I assume that both pumps would be using the same motor on their 7.5hp units?
