57JoeFoMoPar
So with my trusty old Craftsman 15 gallon oil-less compressor that I bought when I was 17 acting weird recently, it's time to upgrade compressors. Frankly, it's long overdue any way.
About a year ago, my father in-law gave me this, which he took in trade for a lot of terracotta roofing tiles. He had no idea if it worked or not. When we were visiting he told me to take it or it was going in the scrap pile. So I did. Honestly, I had no idea about it either other than it was free.
https://scontent-b-iad.**.fbcdn.net/hphotos-prn1/t1.0-9/p417x417/1011407_10101537782358734_1032406335_n.jpg
So there it is. Champion HR1-3 with a 30 gallon tank, R10 pump, and 1.5 hp Baldor single phase motor currently wired for 110v. It was mounted on the back of a truck in it's previous use and had a busted-*** magnetic starter on it. Every gauge on it was smashed. It has a dryer of sorts on the ports, as well as a regulator and and line oiler.
https://scontent-b-iad.**.fbcdn.net/hphotos-frc3/t1.0-9/p417x417/1969298_10101537782892664_1445372075_n.jpg
https://scontent-b-iad.**.fbcdn.net/hphotos-ash3/t1.0-9/p417x417/1924490_10101537782952544_995246827_n.jpg
I haven't fired it up, largely because the electric supply in my garage wouldn't take the draw (I had a small Federal Pacific sub-panel fed off a 15A single pole breaker in the main FPE panel). But I've recently upgraded all my electric so it's game on. The first thing I noticed when I removed the motor cover was that it was wired incorrectly. I don't know if it was running that way or not. If it was I'm sure it wasn't running well. I wired a test plug to it just to see if it'll run and gave it hell. Sure enough, runs nice!
https://scontent-a-iad.**.fbcdn.net/hphotos-prn1/t1.0-9/1978667_10101537782678094_1153959480_n.jpg
So I drained the oil and figured I'd hit it with 2 quarts of Royal Purple compressor oil and wire in a new pressure switch. This one is pretty decrepit. But the oil that came out looks to be in great condition. Promising.
https://scontent-a-iad.**.fbcdn.net/hphotos-prn1/t1.0-9/1622882_10101537782538374_515520798_n.jpg
https://scontent-a-iad.**.fbcdn.net/hphotos-ash3/t1.0-9/534410_10101537782747954_865260746_n.jpg
The plan for now is to change the oil, install some new gauges, install a new pressure switch, and wire it for 220v.
But since I can't leave well enough alone... I'm looking to modify this and could use some advice.
Being a home hobbyist into auto restoration, I'm looking for something that would power a straight-line sander, DA, die grinder and small blast cabinet (one at a time). This Champion (as per the specs in the manual, will only displace 10.5 cfm in its current configuration. But that's only spinning this pump 570 RPM. The manual says I crank this puppy a max 1050 RPM. Here's the manual, specs are on page 7. http://www.flamingoshopserv.com/portals/2/news/partsbreakdown/champion r15 breakdown.pdf
So my question is: What if I stuck a 3hp 3450 motor on this and used a 3.95" pulley, which would yield a pump speed of 825 RPM. I would regulate pressure to 125 psi (I don't need more pressure than that). I would also plumb in an auxiliary 60 gallon tank. By my calculations that would yield around 15.9 displaced CFM. Would this be acceptable? Would it damage the pump? I know it will generate more heat and be less efficient, but all the box store compressors seem to get CFM by revving the piss out of smaller pumps. I could do the same to this, still stay 225 RPM below pump redline, and probably have better longevity than a throw-away pump from Husky or HF. Thoughts?
Sorry about the novel. I'll keep posting pics as progress rolls along.
