Mamrak76
To all,
I have been using this forum for extensive assistance as I needed to replace my home shop compressor. So I am a long time listener, first time caller. I got so much good information from here about compressor and the r15b specifically. I bought a Champion R15b on an 80 gallon tank. It is a custom retiree built compressor and in immaculate condition. I know from previous experience that when you buy something used you change the oil out. So I read that the oil capiacity is 2qts. I ordered 2qts of champlube and filled it up. It was about 1/16 from the top of the sightglass. Here's the problem, growing up my Dad always taught me that on anything with an oil sight glass, the middle is the correct level. Also at my work we have a speedaire 3z182 which looks identical to an r30. It's oil sight glass has a line in the middle. My r15b has no line in the middle. I called Champion and the lady I talked to said she didn't have any experience with this question and said it calls for 2 qts then that's what you put in. I thought the middle was correct. On a vehicle you go by the dipstick because you can never drain every drop out. But when I drained my compressor I looked and I got all but about 1/8 ounce out. Any suggestions on what the proper level is ?
