Champion R30 Pump Questions....
Jay87T
Hey guys I picked this old pump up awhile , its a champion R30. Im going to restore it since it looks like a nice pump. I have been searching forever on the net tring to find a model like this, all the R30 pumps I see dont have a manifold like this one does on the bottom, what year is this thing? also I know its big pump, and I have a true 5hp baldor motor, what rpm should I run this at? oh, one last question, how can I test it to make sure its pumping well..I put my hand on one side outlet tube and its pumping alot, I put it on another side and its not pumping as much as the one side.
J
Jay87T
Hey 930dreamer thanks for the reply, can you check that link out, seems you need speical permission to access it.
Thanks.
Jay
930dreamer
Amarillo,TX and Stinnett,TX
Champions R30 replacement pump is a two-stage, splash lubricated pump and has an RPM range of 575 - 1045, a CFM range of 25.8 - 50.2, and a max PSI of 175. The R30 replacement pump is suitable for a 7.5, 10, or 15 HP motor.
This information is for a new R30 pump. I don't have a log on, just looking for data.
