Champion r15 s have a one piece head/cylinder. Might be a chinese knockoff.
I have that EXACT same pump and it works great. The difference between it and the 15B is it isn't pressure lubed and also doesn't have disc valves. The 15B is a great pump but the 15A is plenty good for a home user or shop. My compressor started out life in a hanger at a small airfiled in the overflow shop. It lasted 10 years of no one changing the oil in it because it was forgotten about. I bought it and lucked into a new old stock 15a from Grainger for $300, took it off the pallet and tossed it on and have about 14 running hours on it now and couldn't be happier!
Thanks but I don't think so.
.. another question.
As long as I run the pump at the recommended speed for a 5 HP motor. (ie 734 RPM) does it matter if my existing motor is 3450 RPM vs 1750 RPM?
Unless I'm missing something I don't see why the pump would care about motor RPM as long as the pulleys are ratio'd correctly to deliver the correct pump RPM?
