Champion ztd1 mechanical auto air compressor drain
zkdiesel
chicagoland cornfields
New to me compressor has this mounted and partially plumbed. I can’t find a manual online
Lower inlet I have going to bottom of tank, one on side above is my exhaust out that’s routed down loft to drain
Top right is T into unloader line coming from compressor to pressure switch port ?
How do I adjust it so it pops right at the 175 psi cut line? Or do I have the unloader line hooked to it wrong?
Any link to a manual appreciated. When I hook up as Is it starts exhausting immediately, so I need to adjust pressure setting or I have a faulty part that needs love
MacMcMacmac
canada
I would suspect a failed diaphragm or stuck internal plunger preventing the proper operation of the drain. There isn't much to these, so maybe a disassembly would be in order.
Z
zkdiesel
Do I T it into the unloader line or do I need to use the unloader exhaust to actuate it? Somehow I feel like unloader exhaust is what I need but my pressure switch and most don’t have a port to capture that as they open air exhaust through a drill port
larry4406
Northern Virginia
Wow my googlefu fails me as well!
I did find one exploded diagram and some installation info in pdf attached.
Also, a link to Hobby Machinist thread where guy fixed his.
Found this boobtube video. It shows how it gets plumbed in starting at around 43 seconds
  • Pages from R10D-R15B MANUALS YR 2000 UP .pdf
MacMcMacmac
canada
So according to the .pdf file, the timing of the bleed down can be adjusted by moving the screw in or out.
Does yours currently bleed off air through the vent holes? If not, then the drain is being held open.
Take the line off of the unloader and ensure that it is not blowing air through the whole cycle. This will also hold the drain open.
If it is, the unloader valve itself may need servicing. It may have a failed seal or o- ring inside it.
Quincys sometimes have a problem with the metal puck under the unloader diaphragm corroding into place. The metal plate under your Champion autodrain diaphragm may be stuck open. It would not surprise me to find a decent amount of corrosion inside the zinc casting of the unloader body itself.
So, rereading your post after writing the above, it seems that you are using pressure switch unloader, probably a needle valve. This will not work, since it will bleed off the pressure from the head and not send it to actuate the autodrain. You would need to use the centrifugal unloader on the back of your pump to do this, if it has one.
MacMcMacmac
canada
Do you have the centrifugal unloader on the back of your pump? It will have a extended cover like the one in the video. It sort of looks like you do. In that case, it would be a simple replumb of the unloader line and a few Swageloks.
Z
zkdiesel
Do you have the centrifugal unloader on the back of your pump? It will have an extended cover like the one in the video. It sort of looks like you do. In that case, it would be a simple replumb of the unloader line and a few Swageloks.
No centrifugal unloader on this unit. So what are my options
MacMcMacmac
canada
The only way I could see you making this work would be to wire in a solenoid valve that opened with the pressure switch contacts, so that the blow down line from the check valve dumped into the port that would have been serviced by the centrifugal unloader. At that point, it would probably be just as easy to install a timed, electronic auto drain.
Z
zkdiesel
I think the key is I need to find a way to put a fitting onto the unloader so it captures its exhaust and routes it to valve. Either they make an unloader fitting with it or something getting brazed up
Z
zkdiesel
Can I remove just my unloader and add this? Set pressure differential super tight at 173-175. Then run throttle port to my drain valve signal line. Puts pressure to it while it simultaneously unloads my compressor head?
American Locomotive
Rhode Island
I looked at similar pneumatic drain valves, and it appears the control signal just needs to be tied in with the normal unloader line. Every photo or video I can find shows them Tee'd into the normal unloader line. It seems they're designed so that under pressure (when the compressor is operating), they're closed. As the unloader pressure signal bleeds down, the valve will briefly open, then close again. When the compressor starts back up, the pressure building in the unloader pipe will reset the valve.
I found rebuild kits for it here: https://www.sviinternational.com/product/as-2201-04-automatic-tank-drain-for-champion/
Z
zkdiesel
I lived in Northern Arizona for 5yrs with a 7.3L; there were days I used to wince turning the key! My glow plugs were long gone, so that thing would start one cylinder at a time until they were all running! The truck would shake like a freight train until all cylinders were firing, but it sure as **** always started!
I was broke at the time, so I wouldn't plug the truck in unless it was going to single digits. Even then, I'd wait until the evening, fire it up and let it get to temp, and then plug it in. Having instant heat in the morning was always the best.
I'm going to assume your wife's truck has functioning plugs and relay!
My valve trips way way way below compressor max output. As soon as you hook like or even hold line blowing air into port with no seal it trips valve
Bleed off time and leakage rate is adjustable with that screw but it can’t change it from a 135-175 set. I think it has to be tied into exhaust of unloaded, hence why they tie it into centrigugal unloader exhaust side correct?
American Locomotive
Rhode Island
It appears champion uses two different types. One type seems to be tied in with the main unloader pressure line. The other type (your type) seems to be hooked to the exhaust of the compressor's mechanical unloader.
It seems that your compressor has had it's pump replaced, and it no longer has the mechanical unloader. Unfortunately I cannot find any pressure switches that have an unloader exhaust port - only an inlet.
Really the only way to make this drain valve work would be with a solenoid valve connected to the pressure switch. But at that point, you might as well just get an electric auto tank drain.
MacMcMacmac
canada
If you could tap the tiny exhaust port for a 1/16" NPT you might be able to capture the blowdown air. I'm not sure how yours is configured though.
The drain should only cycle while the blowdown air is present. If there is air going to it during operation it will be actuating. This is the case if the drain is plumbed directly to the check valve port.
Z
zkdiesel
That’s what I think I need to do by brazing a ****** on
The Cobbler
not sure how easy that will be as you will have to work around the pin that gets depressed when the pressure switch shuts off & purges the unloader circuit.
I would look at using a N/O solenoid valve ( Red Hat ) that shuts when power is applied ( from the pressure switch) and opens when power switch shuts off and just forget about the unloader in the switch
Z
zkdiesel
Just remove pin with it on bench, braze, assemble
MacMcMacmac
canada
Home made banjo fitting? If you have a lathe and some free time, maybe machine a collar to fit down over the valve and use the bottom of the Swagelok nut to act as a retainer? Depends on the configuration of your particular switch.
I am very generous with other peoples time and resources!
gimpyrobb
Cincinnati
My Champion r15 was got second hand. I just hooked a ball valve to the 3/4 pipe output at the bottom and plumbed the drain outside.
larry4406
Northern Virginia
Manual drain = you need to do this and you need to remember to actually do this......
Automatic drain = it happens by itself without intervention.
The OP prefers the latter...
Kind of a useless response honestly. Sorry if this sounds harsh.
gimpyrobb
Cincinnati
Meh.
What size is the auto drain tube? I've seen too many get turd-ed up and stop working. My manual has yet to fail. I have a dual R30 compressor that has auto drains so I'll keep an eye on the thread.
I could care-less what people think of my response(s).
