Hello, I'm new here so thank you for letting me join. I was given an old 230v compressor that is currently wired for 220v. I have a dedicated 240v double pole 30-amp plug wired in my shop for welder and heater use. I’m wanting to know if I can change the compressor wire to the same plug type as the welder and heater? I would be using a 30 amp, 10 gauge plug wire in the same outlet configuration as shown to the compressor switch. Would I also need to change the motor to switch wire to 10 gauge?
