Changing non-grounding cord to grounding?
Erampu
Waterford NY
I picked up an old Craftsman paint sprayer. It has a two-prong cord, which is in pretty poor shape. I'm wondering if I can convert the cord to a three-prong (grounding) cord simply by connecting the ground wire to the metal housing of the sprayer, or would this just ensure my early demise?
mrb
thats a good idea and could help prevent your early demise.
w1im
Western MA
Connecting the ground to the metal case is the correct thing to do. Just make sure it is a good electrical connection.
mrb
and is a mechanical connection, not soldered
jtbinvalrico
Tampa FL
You are right on track. I recently found exposed wires when I opened up an old two-prong tool. When you get inside you very well may find a ground wire in there - some of these old tools had a grounding wire that exited the side of a two-prong plug for grounding purposes. If there's no grounding point inside the tool body, wire up a lug and fasten the ground wire on your new cord to the metal body.
E
Erampu
Waterford NY
Thanks for the input, everyone. This old sprayer is powered by a 1/2 horse motor, and I can attach the ground to the access plate screw.
