Changing out rechargeable drill batteries
Bradley Miller
Blue Springs, MO
No problem. Wish I could do the same for my old B&D Versapack stuff . . . I'm down to two of the gold batteries . . .all the rest were junk. (Not that the tools are much better, but they were gifts.)
Luckydevil
Tampa
Good link! :beer:
I even found the batteries for my old B&D 7.2v drill at that site the guy used (www.BatterySpace.com). I thought I was going to have to toss that thing out.
One thing the guy doesn't mention though, is be super careful when soldering with those batteries (especially if it doesn't have tabs). Overheating one with a soldering iron could lead to bad things and may kill the battery. Be quick with the soldering iron, and I always keep a small spray bottle of rubbing alcohol to cool down things that I have soldered.
Bradley Miller
Blue Springs, MO
I used an Ungar 40 Watt (true) solering iron with a nice fat tip to solder RC batteries. Use some solder rosin (for electronics) on the batteries. I would rough them up a bit with sandpaper and then make everything as happy as possible to solder them together. I don't recommend using a soldering gun as they don't hold their heat as well as a good old iron with a nice tip.
The only caveat to this mod is if you go to NiMH from NiCad . . . if it's a quick charger it may not peak charge the battery right -- perhaps overcharging and shortening lifespan. A NiMH has a lower threshhold voltage transition on peaking. (Delta . . er . . change on voltage is smaller). I've got a computerized charger that I upgraded to allow for NiMH RC batteries, I haven't looked in my power drill battery charger to see what's in there. If it's a long duration charger (like 12 hour ones) then I'd say it would be ok.
Wrote this many moons ago on the subject . . .
http://web.archive.org/web/19980207...radndeb/www/radiowaves/html/soldering101.html
roger55
Fort Collins, CO
Just looked at my DeWalt. The battery pack doesn't have any screws to take it apart. It's sealed and would have to be broken to get it open.
I am not going to buy another DeWalt. I can't believe that they charge so much money for these things and then continue to use yesterday's technology with NiCad batteries.
sjsfire
illinois
I can take my 12volt Dewalt apart at home, it has the torx screws. My 14volt at work however is sealed. I'll try to repair my 12volt battery packs. They are old maybe 8-10 years I'm not even sure??? I know the charge doesn't last very long......I'm glad I didn't toss the whole thing out!
roger55
Fort Collins, CO
bahamasair said:
What Dewalt do you have? All of mine have torx screws holding them together.
Mine is a 14 Volt.
Edit:
Correction. It's a 12 Volt. I have 2 batteries for it and they are both sealed.
paddy
Hay all, I just joined this minute. I am looking for info on the battery resurrection. I followed a link here that said don't buy the info it's here and when I got here I read some, references to it but can't find the directions. I am also new to computers and probably don't know how to use a forum! Can anyone help a newbee? Thanks
mkdive
NPB (Socal)
carefull on charging lipos. I had a lipo blow up in my garage a couple years back (rc battery). thing threw fire everywhere like an exploding volcano. Now we charge those in a 50cal ammo box half full of sand on a cart out on the driveway should one decide to erupt again. I even had one burn my car up on the track, another car smacked into the side of mine and 3 laps later my car smoked, caught on fire and burned up!
Lipos that show any kind of dent,damage, anything out of the norm should be very dang carefull charging them.
brushless w/ lipos are a blast though i have a 18th scale with a 8000k motor that can pull 75+mph! Fun as hell. throws glued tires off, and chews up metal pinion gears like candy. fun for being such a small car!
