Channel Lock Disappointment
Kilgore Trout
Northern Virginia
Got a set of Channellock's (410s, 420s, and 426s) for Christmas and I have to admit I am a little disappointed. They don't seem to slide into the channels very easily, as I quickly learned after my clothes washer broke the day after I received the Channellocks and I had to put them into service. It feels like the finish is grinding off when I first slide them into the channel.
I have a pair of Taiwian-made Milwaukees that are much smoother.
So the question is, did I get a bum set of Channellocks's (they all have the same issue) or do they just need to "wear in" I am afraid that the finish will have to grind off before they operate smoothly.
ihateminimumwage
I remember mine being a little tight in the channels when I first bought them, but they quickly wore in and are plenty smooth now.
Sterff
PA
All of mine were tight like that when new. Put some 3n1 oil on them and that should help.
themiller
Seattle Suburbs
Just got a 460 for Christmas. They needed some loving. After about 10 minutes of "using" them they are now much smoother. No worries - they'll be fine!
jakemac
New England
Dunno :dunno:
All mine were pre-abused before I got my hands on them. The only pair of Channellocks that I've ever purchased new were a pair of 911 cable cutters and a pair of snap ring pliers. I never had a problem with them, but slip lock pliers are a different animal.
K
Kilgore Trout
Northern Virginia
Guess I'll break them in then. Just seemed odd that a high quality brand like channel lock would need breaking in when my Milwaukee's have always run smooth like butter.
Hootbro
Delaware
Other than the dipped handles, Channellocks do not have a "finish". What they do have is a protective clear coating over the exposed metal to inhibit rust formation while sitting in storage or on the shelf rack prior to initial sale.
The first time a new Channellock is put into use, that clear coating will rub and flake away as it is used and worn in. As already mention, just continue to use them normally and they will loosen and smooth out.
nicksnothereman
In the Mojave
That's because all taiwanese tools are awesome. Shhhh...it's a secret.:thumbup:
Hahahaha. Okay more like 90% of taiwanese tools are awesome. :headscrat
