channeling water
purpony
Columbia, CT
Looking for some ideas....
I have a heated attached 2 car garage that i park my daily driven vehicles in. Im in CT so the cars get snow covered all winter long. I try my best to get as much snow off them as possible but that not always the case. The when the snow melts i get water everywhere. Most times i back the cars out and use a large squeegee to get the water out but I always have to make sure there is nothing on the floor so i doesnt get wet.
I ended up buying one of those park smart pads that works pretty well but its a pain in the to take apart and store in the summer and i can use a jack or anything during the winter.
I was wondering if anyone has cut some type of channel around their parking spots in their garage to direct channel water out and not allow it to puddle....
RaceDeck1
Salt Lake City , Utah
We have had many customers channel their concrete floor to help drain water from deep low spots within their floor, then cover with RaceDeck and you never see it
Freefall_Doug
Pomfret Center, CT
Fellow CT poster here. I have the same issue myself!
My garage is a mess with all the snow melt in the winter. It seems to stick around for a long time too.
If I was starting from scratch I would have designed some sort of a drainage system in to the garage.
It will be interesting if any one has any retrofit suggestions.
slickgt1
NYCer here. Had massive issues with rain and snow. Puddles were not even under the car, but everywhere else, and no where near to the exit. Was a massive pain in the ***. Corrected pitch while setting tile. No more issues. I now hose down my floor just for the heck of it.
Flooring For Garage
I still believe it should be code to have a 2" pitch back-to-front on newly poured floors in northern climates... It would certainly help with puddling snow-melt and still be subtle enough a pitch that it would not cause other problems.
Unfortunately, short of resurfacing your floor, I don't know that you could do much more than you already are...
slickgt1
Slick,
What was involved with reseting the pitch of the floor during the tile job?
Check out post 2. You can see what I did. Post after show as it progressed.
Yea there are a lot of pics. So wait till they load.
cbr1000
I've got the same problem during the winter in Missouri... puddles under the rear of the cars. Drives me crazy, lot's of winter squeegy use.
66HertzClone
Long Valley, NJ
I had this problem until I put the Racedeck tiles down. I used the Freeflow tiles under both of the daily drivers and have never looked back. I did use the shop vac this spring to pull up the sand/grit that had accululated in the slots of the tiles. Sorry for the crappy cell hpone picture.
