Charging external battery via cig lighter
seagull369
I like to keep an extra 12V battery in the back my truck, just in case I need to give myself a jump. Instead of dragging out the household charger to keep it topped off now and again, I was wondering if I could just charge it via the cigarette lighter using a cig lighter plug and alligator clips. I wouldn't plan on using the plug to charge the battery if it was in a near or fully discharged state. The run would only be about 3 feet.Not sure if this is the best idea, so thought I'd run it past you guys 1st. I believe the lighter circuit is fused at 15A,
Any thoughts?
Zewnten
Cigarette lighter plugs usually don't have very large wires supplying power, another issue would be float charging the battery .I'd recommend picking up a lithium ion jump pack.
