charles parker 88 vise restoration
golovin
Golovin, Alaska
I am restoring an old vise my Dad bought over 50 years ago. The main nut is missing.
Are all the main screws and nuts interchangeable?
Where can I buy a replacement main nut?
kwoswalt99
Detroit
They are interchangeable for the same models. I would try some of the vise parts threads here, and then ebay. Good luck!
ALLFAST
Be persistent and you will find one in no time. Simply Google Charles Parker model 88 (insert appropriate term) and you may be pleasantly surprised.
G
golovin
Golovin, Alaska
I am also restoring a Reed 206 vise with very corroded lead screw. It is so rusty that it may not be salvageable, for sure will not turn. I was able to get the main nut pin out.
Can I drive the nut and the lead screw assembly out of the dovetail forward or will it only come out backward on this Reed 206 vise?
G
golovin
Golovin, Alaska
The Reed vise lead screw is extremely rusted.
Can sand blast the screw to try and get it to turn or will it ruin the threads?
Or any suggestions.
I had the vise in an electrolysis bath with 2 battery chargers for 2 full weeks.
sonoronos
Phosphoric acid, 33%. Full immersion. Electrolysis has nothing on phosphoric acid. Phosphoric acid converts red rust to ferric phosphate directly without anode shadowing.
Packard V8
Spokane, WA
Question. I've used phosphoric acid to clean stationary parts but where there is movement and substantial load bearing involved, as with a vise screw and nut, how does the "rust converted to ferric phosphate" react?
The Reed vise lead screw is extremely rusted. Can sand blast the screw to try and get it to turn or will it ruin the threads?
Sandblasting won't harm good steel.
Or any suggestions.
After sandblasting, then heat. Even if you've only got a propane hand torch, it will usually get the nut hot enough to break the rust bond. And no, you won't damage a cast iron nut with a propane torch.
jack vines
sonoronos
It rinses right off the steel. It turns into an aqueous ion and no longer remains attached to the steel. Once you wash the steel down, it will be bare steel and will flash rust.
There is no fundamental chemical change to the metal. No reduction in strength. Nothing. This is a surface reaction.
Note: If the part's dimensions change because it was mostly rusted through, of course its strength is compromised. But this is no different than what happens if you use a stainless wire brush or electrolytic rust removal.
Note: Do not leave the part in the phosphoric acid for days. This is not weak sauce electrolytic rust removal. The acid will etch the steel as it oxidizes in the water after the rust is gone.. It is slow, but it will happen. I have left steel parts in a phosphoric acid solution for a week and there was severe dimensional change.
