topher5150
I only need to re-taper two holes on some steering parts for my 47 Ford. Do I need a $100 tool, or could I get away with a couple of $5 Harbor Freight tools for this one project?
-You still haven't really given enough info here. Is the existing hole already tapered but the wrong angle? Is this a component you made? Most reamers are only capable of cutting about .0075 per side, a tapered milling cutter will cut more than that. So if you're re-cutting to make a different taper you really ought to trig the amount of metal removed or you might break off the reamer. What machine are you going to use to drive the reamer/cutter? Have you actually checked the male tapered component?I don't know the thickness of the part, less than 1", but I only need to taper about halfway.
I'm not removing a whole lot, maybe a couple thou to get the tierod end in. It's for tie rod ends on a pitman arm and an axle spindle.
I can get some more accurate measurements when I get home
I think this is getting a little more complicated than I intended.You need the taper tool to do it right. You can buy weld in inserts that are tapered, but it is slightly questionable in my mind. Seems like there may be another option or two on the Speedway motors site.
-You asked for advice and were given replies by several other members other than just me. I guess if you can't be bothered to investigate how to make the job come out right then you need to discover how it can go wrong by yourself. I do wish you good luck though.I think this is getting a little more complicated than I intended.
All I read from that us acknowledgement. You seem to take it as apathy.-You asked for advice and were given replies by several other members other than just me. I guess if you can't be bothered to investigate how to make the job come out right then you need to discover how it can go wrong by yourself. I do wish you good luck though.
-You may be right that I'm reading it wrong. A lot of people get on internet boards with notions that aren't very well thought out, mostly driven by a budget and lack of experience. Nothing wrong with staying within a budget either. I asked a few simple questions to give the OP some expectations based in the reality of metal working. His reply was that it was getting more "complicated" than he intended. OK....he's not very good at explaining his project. That's ok too. But if he hasn't even checked the tapered reamers he linked to then he's not bothered to find out IF they even match the required angle, let alone the feasibility of carving out chunks of forged metal that are beyond the scope of a hand reamer. The lack of experience shows in this and that's ok too.All I read from that us acknowledgement. You seem to take it as apathy.
Yeah, I think you took a big leap there-You may be right that I'm reading it wrong. A lot of people get on internet boards with notions that aren't very well thought out, mostly driven by a budget and lack of experience. Nothing wrong with staying within a budget either. I asked a few simple questions to give the OP some expectations based in the reality of metal working. His reply was that it was getting more "complicated" than he intended. OK....he's not very good at explaining his project. That's ok too. But if he hasn't even checked the tapered reamers he linked to then he's not bothered to find out IF they even match the required angle, let alone the feasibility of carving out chunks of forged metal that are beyond the scope of a hand reamer. The lack of experience shows in this and that's ok too.
Asking questions about things you don't know is part of what the internet is great at. But if you aren't willing to investigate a few simple suggestions/facts it really doesn't matter how much you convince yourself that it will indeed work. The refusal to learn is often just abject laziness and it's all too common on the internet, I see it on several other boards I'm a member of.
If I've misjudged the OP then I've jumped too soon to an estimation. However, if my assumptions are correct then sometimes the results of a self inflicted screw up can teach what the ego refuses to consider. I did wish him/her good luck and I meant that.
-Possible, but at this point in time I don't feel I did. Time will tell.Yeah, I think you took a big leap there
I took the opposite approach and ordered the cutter and did mine on my mill. We both probably have a near identical amount of money and effort involved.Am I correct in guessing that you are upgrading the steering box on your '47? If so I did this many year ago on my '47. As I said above the local chassis builder had the right cutter and did the job for a nominal price. I took the drag link and the steering arm in and the job was done.
lg
no neat sig line
And yet, here we are...I never respond to any thread that has the word cheap in the title.
This is a tap that I ground to a 7* taper for something similar. If you are interested in it let me know.I only need to re-taper two holes on some steering parts for my 47 Ford. Do I need a $100 tool, or could I get away with a couple of $5 Harbor Freight tools for this one project?
