Cheap alternative ball joint press
Torqline87
About had it trying to fenagle my clamp style ball joint press so i figured something out the night before the job after a few cold ones...
T
Torqline87
Harbor freight racing aluminum jack and pinion socket with a dead blow works pretty effectively. saved about 20 minutes per side.
Jswain
Calgary, AB
Especially when the hole in the control arm gets messed up from beating a stuck one out. I do agree though the clamp style is super annoying to line up by yourself
Murphy4570
West Deptford NJ
That method won't work for really stubborn ones. You'll just end up lifting the whole damn vehicle up.
Glad to see you got the job done though. Balljoints are always a PITA.
T
Torqline87
I do agree with you guys, from doing kingpins on Heavy duty winch trucks in the oilfields to small ball joints on these f150s in the gulf, I usually torch out the center of the ball joint when they are seized up and do a pretty good job of cleaning the ball joint bore with my fine paper die grinder. works pretty good and the ball joints usually pop right in. Been doing a ton here in the gulf and when my clamp struggles to get em out i just torch the center of the ball joint at and it usually pops out with ease. Hope that info helps:beer:
platform389
You are lucky. Members of the 200,000+ mile ball joint club would laugh at you. They are very happy where they are and require much more effort to remove.
