Cheap ceiling?
Justin
KY
Im wanting to put a ceiling in my garage to hold some heat in and was looking for a somewhat cheap materail. I was looking for some styrofoam sheet insulation with a foil backing to use for a ceiling, but for some reason I can't find exactly what I was looking for. I found plain styrofoam with no backing which is flammable, so I don't really want that.
I thought about just plain old OSB with pink rolled insulation above it. What do you guys use?
locomike
I got 3/16" hardboard underlayment from Lowe's. $9.95 per sheet. Just put some insulation above it.
J
Justin
KY
Thats my kind of price. Forgive my ignorance but by underlayment do you mean plywood?
locomike
No it's like a masonite type material. You'll like it. Just put it up and paint it. I have a thread you can c it in. In the gallery. B4 & After ceiling!
J
Justin
KY
Well as far as the before pics UH :lol: there is nothing there. Nothing but bare 2x4's down low. Last year my insulation was putting a garbage bag over the whirlybird on the roof of the garage to keep the torpedo heat from running straight out.
Im trying to get my ChevyII toghether by late spring or summer and getting the motivation to go out and freeze to death just isn't in me. Im not looking to have balmy 80 t-shirt weather in there just a little warmer climate.
locomike
That's kool, before I got my building I had a 12x24 shed. No elcectric. I built my 4wheeler motor out there in the cold with an extension cord from house. Gearheads do that a? lol. GL.
mhoffm911
I have unfinished (yet) drywall on my garage ceiling. My wife and I just spent a couple of days blowing in insulation on top of it and our main house attic. I can already notice a difference in the amount of sound in the garage. I am going to be working on an attic stair cap this week (since she won't let me buy the ready made one at Home Depot since it's $75). I found plans on the net for making one out of a sheet of foam board insulation. See plans below:
http://www.jacksonemc.com/Do-it-Yourself-Energy-Projects.43.0.html
Back to the insulation part...if you buy 20 bags (at around $9 per bag), both Home Depot and Lowes will rent you the blower for free for 24 hours. We put 32 bags in our attics (19 in garage and 13 in main attic which already had some).
ponjohn
CT
I am in the same exact boat.
I got a price for the back half (22x30) and it was 2200.00 for zip up. HD and Lowes no longer sells corrugaed metal. The masonite mentioned is like 8-10 per sheet depending on thickness.
Another option is 1/4 inch sheetrock, no difference in price about 8 bucks/sheet.
g17jimmy
I'm doing 7/16 OSB in my garage. It's $5.55 for a 4x8 sheet at Lowes(or home depot).
IDASHO
Moscow, Idaho
No.
OSB = oriented strand board.
And IIRC, a 4x8 sheet of 7/16 OSB weighs in about 48lbs per sheet.
I looks a bit like the old chip-board, but it is completely different.
g17jimmy
I'll post some pics later tonight. Hopefully the ceiling/attic floor will be all done tonight.
timgr
Medford, MA USA
Luan plywood is much, much lighter than OSB, though not quite as cheap. Close though.
I think OSB is commonly used for side walls, for the structural strength. You don't care about that for the ceiling though.
Both will burn - that's why sheet rock is used so much. Heavy, but cheap and fire retardant.
engnerdan
Minnesota
I used 3/4 double foil faced foam board on my vaulted ceiling (well against the rafters). I was going to put fiberglass up but was told you do not want anything touching the wood that the singles are attached to, so I went with the foam board and attached it to the underside of the rafters. This leaves a 3.5 inch air space which increases the R value of the foam I used to something like 9 from 7 (for just the foam). The only trouble with the foam board is the goofy washer headed nails are a pain to drive into old hard wood.
-Dan
PAToyota
South Central Pennsylvania, USA
Just one thing to remember with all of this exposed insulation, foam, or wood - it is not fire resistant... Going with 5/8" drywall may be more expensive, but you then have a fire barrier. Codes will dictate the necessity of a fire barrier for an attached garage, but even in a detached garage the peace of mind of not having to worry about a grinding or welding spark lodging in exposed foam insulation...
