bad_idea
I am looking to buy a cheap pressurized abrasive blaster. I see HF has a 20lb unit for $89 or a 110lb unit for $160. I don't plan to do a lot of blasting, so 20 lbs should be enough capacity. Worse case, I have to fill the hopper multiple times. Again, I do not foresee me using this thing a lot. I have a Quincy 325 run by a 5HP motor - puts out 17CFM at 175 psi, should have enough air for a small unit to run well.
Suggestions for something cheap that will do the job? I also do not mind modifying/upgrading the unit over time to improve it.
