kf4zht
Discovered this over the weekend. It works better than some parts washers I have used. I copied this from my blog.
Ingredients:
* 5 Gallon Bucket
* 2+ Gallons Purple Power (or white lighting, simple green, etc)
* 2 Gallons Water
* Drill (Cordless is easiest and safest)
* Plastic, Squirrel cage style paint mixer ( http://www.discountpaint.net/store/product.php?productid=7035 ) Available at home depot
Mix the Purple Power and water in the 5 gallon bucket. I would put about 4 gallons in the bucket. More cleaner = more power, but 2/2 is about right. Put the parts in the bucket. I found about 2 piston/rods and 1 main cap in at a time. Let it soak for about 20 minutes and then using the drill on torque setting and use the paint mixer to agitate the solution for about 1-2 minutes. Remove parts, rinse and dry with an air gun. Cleans parts well and quicker than a parts washer.
Note: this will clean oil/grease. To clean carbon build up soak time must be longer. In that case one could use a drill press to keep the fluid moving longer, not real efficient though.
Ingredients:
* 5 Gallon Bucket
* 2 Gallons Water
