Cheap small TIG welder
Massachusetts
Does anyone have a recomendation for a small tig welder (220amps) that costs under $1000? I have seen several on ebay, and have wondered if any of them are any good? I would be welding mostly steel, and maybe aluminum.
mike13u
S.Florida
The Miller Diversion and the Hobart EZ TIG are both right at about $1200 delivered. Thats $200 more than you want to spend right now but it will be a lifetime of "Im glad i spent the $200" when comparing those to most of the sub $1000 machines available.
BigSteve63
SW Missouri
You might check with your local welding supply. I was looking for a tig worth the money and one of the LWS here had a couple in on consignment. Also, keep checking eBay and CL in your area. I wound up buying a little used Precision tig 185 for $600. Great machine, if I can just figure out how to use it! :dunno:
rsanter
visalia ca
if those cheapies are a 'scratch start' unit then all the are are an arc welder
you can tig with a basic arc welder by adding a TIG torch and regulator
bob
CKC
SE Michigan
A new machine under 1K will be something made offshore, Friend of mine has an Everlast 200 seems to do everything he needs, does all the Tig Welding for the shop he works at, and its paid for itself.
I have a Miller Diversion 180 myself, and just would not buy one of the offshore brands.
1930case
Countless miles of carbon and stainless pipeline and and nuclear reactor piping are welded with scratch-start DC TIG.
http://weldingweb.com/showthread.php?t=38106
Learn that way first, then buy the most powerful purpose-built TIG machine you can afford later. We taught many successful students that way (until state budget cuts killed our funding) using Idealarc 250 transformer power sources.
You can get a new Hobart AC/DC Stickmate and a new scratch-start TIG setup very reasonably, and have stick and DC TIG capability in a solid package for under a grand that will last for many years.
The scratch-start setup can be connected to ANY other appropriate stick or TIG machine as it merely clips to the stinger (or you can bolt a lug to the terminal ring and connect it to a Dinse or Tweco quick connector with a few inches of cable).
