The malfunction indicator lamp (MIL) or service engine soon (SES) light is for emission related faults. The service vehicle soon (SVS), if present, is for non-emission related faults.
Service Information
2009 Cadillac CTS | CTS (VIN D) Service Manual | Diagnostic Overview, Starting Point, and Programming | Vehicle Diagnostic Information | Diagnostic Information and Procedures | Document ID: 1800770
Powertrain Diagnostic Trouble Code (DTC) Type Definitions
Emissions Related DTCs
Action Taken When the DTC Sets - Type A
• The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
Action Taken When the DTC Sets - Type B
• The control module illuminates the MIL on the second consecutive ignition cycle that the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
• The following applies to misfire DTCs:
- If the control module detects a low level or an emission level misfire condition during 2 consecutive trips, the control module illuminates the MIL.
- If the control module detects a high level or catalyst damaging misfire, the control module flashes the MIL at a rate of once per second.
- If the control module detects a misfire during 2 non-consecutive trips, the stored conditions are compared with the current conditions. The control module illuminates the MIL when the following conditions occur:
• The engine load is within 20 percent of the previous test that failed.
• The engine speed is within 375 RPM of the previous test that failed.
• The engine coolant temperature is in the same range of the previous test that failed.
• The following applies to fuel trim DTCs:
- If the control module detects a fuel trim condition during 2 consecutive trips, the control module illuminates the MIL.
- If the control module detects a fuel trim condition during 2 non-consecutive trips, the stored conditions are compared with the current conditions. The control module illuminates the MIL when the following conditions occur:
Conditions for Clearing the MIL/DTC - Type A or Type B
• The control module turns OFF the MIL after 4 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Non-Emissions Related DTCs
Action Taken When the DTC Sets - Type C
• The control module stores the DTC information into memory when the diagnostic runs and fails.
• The MIL will not illuminate.
• The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Failure Records.
• The driver information center, if equipped, may display a message.
Conditions for Clearing the DTC - Type C
• A current DTC Last Test Failed clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other non-emission related diagnostic.
• Clear the DTC with a scan tool.
Action Taken When the DTC Sets - Type D
• The control module will take default actions but no DTC will be stored in Failure Records.
• The MIL or SVS will not illuminate.
Conditions for Clearing the DTC - Type D
© 2009 General Motors. All rights reserved.
