Check my heat loss calculation
Tracs
Manitoba, Canada
I've done a heat loss calculation spreadsheet for my 40x60x12 shop under construction.
Does anyone want to check it and see if it looks correct? It seems a little high to me, mostly the air infiltration BTUs.
IDT 60
ODT -27
I can't attach the spreadsheet directly, but this link may work. If not I'll try again from home after work.
https://docs.google.com/spreadsheet...ouid=112511685918288083149&rtpof=true&sd=true
PoorUB
Fargo, ND
I looked it over and a bit more information there than I care to look through.
Was the final heating BTU 68,000? If that is correct, that seems about right to me.
T
Tracs
Manitoba, Canada
Yes, close to that. Here is the final calculation values.
Infiltration seemed high BTUs. I was just wondering how many air changes per hour a spray foamed garage building would actually have.
40x60x12
2x6 walls with at least r20 insulation
R50-R60 attic insulation
R12 under the slab
2" around perimeter slab
2' frost wings buried at 45 degree angle around perimeter
