Thanks all for your feedback, I'll try to answer them all. If I missed one, remind me!
The box on the upper left is a inside disconnect for the A/C, fed from a separate meter, with another outside disconnect by the condenser. It was there when we moved in over 20 years ago. It's feed with 6 gauge SER, and really old SER in conduit outside to the A/C disconnect. I'd be happy to fix it if the inspector wants.
Feed to the garage is MHF 2-2-4-6, 4 being the max in my ground bus. Inspector approved this for the garage feed after wire and cable your way sent the wrong stuff. They gave me a heads up before it arrived, and credited the difference. Very pleased with the process. That's dirt on the cable, not damage. Good eyes!
The conduit with garage feeder does have a locknut, but no separate bushing. What kind of bushing? Does it go inside the conduit?
No anti-oxidant on the MHF, I didn't think it's required for connection to the breaker or neutral/ground bars since they are aluminum. If it's a good idea I have some.
There is one knockout that's not completely removed, but the hole does have a bushing. I'll remove the rest of the knockout.
There is a 6-3 w/G in what looks like a 1 1/4" knockout with the wrong size clamp around it. Trying to figure out how to best fix that. If a rubber grommet is compliant I'll add one or the Arlington black buttons if they come in that size. Home Despot doesn't carry them that I've found.
Dan
