hunterguy86
I am starting on my house and shop build. The next step in this process is to build my workshop, which will be 24x30. This is a single person shop for general mechanic work and woodworking. Biggest load will be my 110V Hobart 140 Mig. I plan to add an air compressor in the future.
Anyways on to the plan. For visual reference, please see the attached picture. Excuse the crudeness of it lol.
The power company is setting my pole with 200 amp service. They are providing a meter can and load center (200 amp, 8 space 16 circuit with feed through lugs.) I plan to treat this as my main panel and put a sub in both the house and the workshop.
The workshop will be about 80 feet from the power pole. I am planning on putting in a double pole 100 amp breaker and using 1/0 wire and bringing 100 amps to the shop. The load center in the shop will be a 200 amp panel (probably a 30 space) just in case I need/want to upgrade in the future.
From the shop panel I plan on installing another sub in the shed which will be a 2 space, 2 circuit with a disconnect switch above it. It will be about a 50 foot run of wire from the shop sub to the shed. I plan on only having a light and one plug, so 30 amps should cover this. I figure #8 should be fine here.
The run from the pole to the house is to be determined at this point. I will work with the electrician during construction on this.
Everything will be below ground in conduit and THWN wire. Inside wiring on the shop and shed will be NM and sized appropriately for each circuit.
There are no codes/inspectors/permits required here, as we are in the county but that is irrelevant to me as I want this done to code, inspector or not.
I will be doing the shop and shed wiring myself as well as the attachment to the main panel.
Am I on the right track? Anything I missed?
Thanks for the help and sorry about the long read.
