What I get from this is that if you are a pro then you won't divulge any information about the way that you have found that works great or the material to use that works the best.
Its not about divulging secret information. Our suppliers will not sell to the public. I cant say this enough, there is no one single product or installation technique that works for every surface.
I am pretty sure that 95% of the guys that are looking to finish the floor on this site all have the same requirements. Mine are something that is durable, won’t do the hot tire pickup, and looks great. I just want to park my truck and do a little bit of mechanic work on it.
If thats the case then find a pro installer with a good resume and referrals and a good guarantee. You might pay a little more but in the long run you get no headaches and stress from a failed floor and then pay more to fix or cover up.
I have been in the same trade for 28 years (it has absolutely nothing to do with flooring though) and if someone asks my opinion then I will answer to the best of my abilities.
Well then you, as a professional should know that you get what you pay for and a jack of all trades is a master of none. You want your floor done right, no headaches.......get a pro.
We are just a bunch of DIYers that need a little (OK a lot) of guidance with doing our floors.
do a search of older posts and see what other DIY have done and what type of success or failures they have had and take a shot
To all the Pros out there - Is there anything that you have had excellent success with?
Yes, but none of my material is sold to the public and only sold in quantities.
Is there anything that you have had no success with, If so, what was the cause?
1. Acid etching (very inconsistant and high risk for failures)
2. using bondo or a hard curing patching material
2a. before patching cracks, they need to be chased open first.
What is the best way to prep the floor, acid or grinding?
1. diamond grinding or shot blasting
Have you ever had hot tire pickup happen? If so what was the most probable cause?
Yes, when I first got into this business 5 years ago. bad prep, acid etching and or using crappy patching material.
What part of the job sounds the easiest but is actually the hardest?
finding a good flooring contractor
Any constructive info given would be greatly appreciated by many
You have 2 choices;
1.If your going to do it yourself, find a place that rents diamond grinders (with diamond inserts) or shot blasters. Then follow the directions to what ever product your gonna use.
2. Hire a qualified, well reffered pro in your area.
Hope I helped
ps
Wolverine, the failures I mentioned where with your products.......Just Kidding
