Cherry picker rotisserie build.
Status
Not open for further replies.
Ross/Kzoo
Richland Mi.
I'm not seeing it yet. Keep those pictures coming.
The suspense is killing me!
Falcon67
Merkel, TX
Slick - nice source of parts.
>That was smart. How much for the lifts?
he said craigslist, so since I paid $99 for mine new at Pep Boys and the HF units are running $190, I'd guess the CL prices would be $350~500 each used :lol:
brownbagg
when i made mine, i did not use the cheery picker plan, I just did the stock height and I pick the body up with the cherry picker. I got about $40 in mine
plow
Louisiana
WTF? Rotisserie? Just looks like some kind of rolling post with adjustable height.
Confucius say, Patience is necessary, and one cannot reap immediately where one has sown.........in bed. Wait no, I think that was my uncle.
ar2stp48
Magnolia, Arkansas
Looking good; keep the pictures and progress coming. I can see where you are going. It is obvious from a couple of comments that some have not followed and threads on rotisserie designs or construction.
Vegaman_Dan
Pacific, WA
Do yourself a favor and weld in some gussets at the base of the vertical shaft. Won't take much, but could be huge in making it strong and safe.
NakeDiesel
oklahoma
I love my autotwirler rotisserie. I've had my 69 Camaro on it and sand blasted it and then used it to spray epoxy on it.
I have my son's 93 dodge cab on it right now.
They are very handy to have if you are doing body off restores.
HAY YOU
You do really need to turn that welding machine up a little more. The weld looks ropey not enough penetration.
HAY YOU
My suggestion was from a safety stand point where you might get hurt as was the comments from others about gussets or more weld. If you would turn your machine up & practice a little on some scrap pieces the obvious would become clear to you. If you consider burnt paint or weld squeezing out the back side of your bevel... penetration you'd be assuming wrong. I don't know of any welder that looks at the back side to judge the quality of his weld. Or if any welder considers the heat range right by just setting the dial with out actually setting the machine by welding on a test strip (scrape piece). Well just carry on. I was only giving friendly experienced advice.
MScott
Eastern Ontario
Damn, liquidh8, I wish you would reconsider and just ignore those idiots. I was really looking forward to seeing how you did this.:headscrat
Status
