Chicken Wire/Safety Glass Sash
Bamacruiser98
Good evening, I'm currently breaking down and restoring an old wire glass sash. I collect several types of glass but the industrial stuff is my favorite. This one had a few coats of paint over the last 80- 100 years so I really needed to break it down fully to get it back to how it was sold. This sash didn't have your typical glazing holding in the 1/4" thick glass instead each pane has 4 pieces of steel that are L shaped if you're looking from end to end, said peice bolts to the adjoining panes piece or to the outer sash frame with a small bolt and nut. Now, once those 24 pieces are removed you pull your panes and under the panes was what I'm assuming was at once time a sealant. It was a red, chalky and somewhat waxy material. I'm guessing this was some sort of heat resistant sealant but could be wrong. For those of you that know this field a bit what could I use in place of that bc I highly doubt that stuff has been produced in the last 50 years and was probably highly toxic. I would like to run a bead of some sort of sealant. Would a certain type of gasket maker work? This will be a display piece in my shop so it doesn't have to be perfect.Screenshot_20260221-000521~2.jpg
wssix99
Chicago, IL
Yes, that window is fire rated and the wire in the glass helps the panes gain fire resistance.
I would use whatever you like to glaze the panes. (Since it is loosing that fire rated function.) I would think the lead paint on that window is the most hazardous thing to watch out for.
