Chimney cap
derek_m
When I bought my house the home inspector flagged the chimney that it needed a cap. I'm not too familiar with what I have here. There are drain holes in the vent that direct water out to the roof. This is for a gas insert fireplace. Is this vent not correct? I don't see any mount locations where the cap would be missing.
gmcgeo
Never seen anything like this before.
I do not see how it vents and pulls fresh air. unless the fireplace is a be vent and not a Direct vent
PoorUB
Fargo, ND
so much of this is dependent to the manufacturer of the insert. Figure out what brand and model of insert you have, get and install manual and see where it leads. Or, find out who installs that brand in your area and contact them.
Very possible that it might not need a cap and the inspector doesn't know what he is taking about. They generally are not as knowledgeable as one would hope!
Jackfre
N CA
Poor UB is correct. The manuf of the appliance will call out acceptable manuf of vent components. It is not allowed to mix and match. My question, is there a liner for the masonry chimney. I am sure it is required. I have never seen that termination piece before either. It is flush with the top of the chimney and may be why it was used as most conventional systems would have a bit of pipe above the top of the masonry with a flat flashing for the pipe extending above and a typical B or Direct vent cap, depending upon type of appliance.
ybnormal
how old is the fireplace/house? has this been replaced before?
I had to build a new crown on my chimney about 5 yrs ago because the original builder never did it right in the first place. how is your cap going to prevent any weather/water ingress? that design makes no sense.
D
derek_m
The house was built in '79. The insert is one of those gas logs. From what I can tell this cap/vent appears to be original and does not let any weather in. I just am not familiar with the style or if it is correct.
The inspector picked up on some good items, at the same time he failed to notice there wasn't a single smoke detector in the house. That's why I'm questioning if there is even anything wrong.
ybnormal
doublecheck with the firecode in your city/county, or call a local chimneysweep (who should know). I'm not familiar with gas fireplaces but even to me, how is that thing supposed to prevent water from coming straight down the exhaust pipe? It should have some sort of roof on it with side vents to draw off the fumes
gmcgeo
Gas logs, if vent free does not need a cap.
If they are vented gas logs then this cap will be fine
FredWanaker
NorCal
the only concern I would have is that if water can find a way down the flue, and if you get 30" of rain a year then 30" of rain goes into your chimney masonary / flue, or worse leeches thru into the surrounding structure.
rodrigger
sidney
does not look like the right cap for direct vent insert or b vent for that matter. never seen louvers on a chimney vent system before. It has to have a cap to keep element out.
gmcgeo
Its a log set, not a direct vent. yes elements get in. it should be changed. however it does not effect the log set unless its pouring water inside
nadogail
Coronado, CA
One of the rental properties was getting Wind Blown Rain in an exhaust vent, the cap on the exhaust pipe only diverted falling rain. I have no desire to climb on a concrete tile roof of a two story house. A local roofing company put an appropriate cap on the exhaust vent for only $250.
gmcgeo
that is a great deal
75gmck25
Alexandria, VA
